77 Cruising Wagon Front Seats
Date: 04/12/2017 12:37 pm
SOME PARTS FOR SALE
Date: 01/11/2017 10:45 am
Dumping '80 yellow Pinto
Date: 06/21/2017 03:45 pm
convert to stick
Date: 05/19/2018 09:26 pm
I need a 1976 hood
Date: 12/19/2016 06:02 pm
2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
6.6.75 carrier
Date: 02/14/2018 06:47 am
Date: 09/26/2019 05:31 pm
Date: 08/08/2017 01:44 pm
  • Online today: 1,292
  • Guests: 517
  • Total: 517
smal block mounts
Started by Starsky and Hutch, July 29, 2008, 08:05:44 PM
ADaughen
Quote from: Starsky and Hutch on August 01, 2008, 02:18:31 PM
no to your question on the stat,,,,,and  there is a year and a model of car that their mounts will fit right in.......
So what you're saying is... I'm going to have to hunt you down and torture the info out of you.   :evil:
c'mon... my '89 302 is begging to slide between the frame rails.
'78 Cruisin' Wagon
ADaughen
Quote from: Starsky and Hutch on July 31, 2008, 08:18:43 PM
no thats not it .......some esle wanta try at it
Is this a quiz that you know the answer to or do you just not want to accept the status quo?   ???
There were older SBFs (say early 60s 289s) with different engine mount placements... it might be possible to figure out which mounts are needed and go with those...
'78 Cruisin' Wagon
None that I'm aware of, even if you use the MII mounts you have to move the left frame mount back 1". Am I right on that guys?
 what over the counter ford motor mounts can be used to put a small block in 74 up pinto . you can slide the bolt right thru it & into stock perch on car.
