Early Rare Small window hatch
Date: 08/16/2017 08:26 am
Date: 04/12/2017 08:15 am
Date: 01/24/2017 12:36 pm
Date: 01/28/2021 03:49 pm
Various Pinto stuff for sale.
Date: 11/21/2018 01:56 pm
Date: 09/19/2019 04:43 pm
1979 Pinto Sedan Delivery
Date: 06/15/2019 03:30 pm
SVO SWAP
Date: 03/15/2018 03:12 am
Date: 08/09/2018 07:49 am
  • Online today: 1,292
  • Guests: 521
  • Total: 521
smal block mounts
Started by Starsky and Hutch, July 29, 2008, 08:05:44 PM
ADaughen
Quote from: Starsky and Hutch on August 01, 2008, 02:18:31 PM
no to your question on the stat,,,,,and  there is a year and a model of car that their mounts will fit right in.......
So what you're saying is... I'm going to have to hunt you down and torture the info out of you.   :evil:
c'mon... my '89 302 is begging to slide between the frame rails.
'78 Cruisin' Wagon
ADaughen
Quote from: Starsky and Hutch on July 31, 2008, 08:18:43 PM
no thats not it .......some esle wanta try at it
Is this a quiz that you know the answer to or do you just not want to accept the status quo?   ???
There were older SBFs (say early 60s 289s) with different engine mount placements... it might be possible to figure out which mounts are needed and go with those...
'78 Cruisin' Wagon
None that I'm aware of, even if you use the MII mounts you have to move the left frame mount back 1". Am I right on that guys?
 what over the counter ford motor mounts can be used to put a small block in 74 up pinto . you can slide the bolt right thru it & into stock perch on car.
