Date: 11/11/2019 03:38 pm
Early 2.0 engines
Date: 05/09/2018 12:45 pm
pinto floor mats??
Date: 01/11/2017 07:27 am
2 liter blocks and heads
Date: 03/28/2018 09:58 am
Date: 01/20/2018 07:51 pm
free transmissions
Date: 11/28/2019 10:21 am
Date: 03/15/2023 02:16 pm
Date: 09/03/2018 08:58 am
1978 Squire wagon 6 Cly
Date: 02/16/2020 05:42 pm
  • Online today: 577
  • Guests: 489
  • Total: 489
5 speed behind 2.0
Started by oldblu72, December 13, 2005, 10:43:20 PM
Quote from: 77turbopinto on December 14, 2005, 08:32:11 AM
The 2.0's and the 2.3's have the same bolt pattern. The dowel pins are different so you will need 'stepped pins" to bolt up a 2.3 t5 to the 2.0. Also, there are different t5's for the 2.3. Just swapping the bells, llike putting a 2.3 bell on a v8 t5, won't work. If you don't want to re-build the t5, get one from a 2.3 to start with.
BTW: Welcome.
Actually, to clear that up. The 2.0 and 2.3 only share the bottom 4 bolts being the " same" there are two additional bolts at the top of the 2.3 belhousing that do not work with a 2.0 application/T5 swap. This is were some fabrication will come into play.
BTW: Welcome.
There are lots of 5 speeds that will fit behind a 2.0 but none that are a direct bolt on. Please refer to out FAQ section and look at all the T5 information.
oldblu72
is there a ford 5 speed trans that will fit behind a 2.0? i thought a later straight 6 mustang might have the same narrow bolt pattern. anyone try this?
