1980 Pinto taillights
Date: 12/26/2017 03:48 pm
Date: 01/18/2017 05:35 pm
Date: 08/01/2018 01:17 pm
Date: 12/20/2016 10:47 pm
Date: 12/10/2016 04:11 pm
Clutch Cable Needed
Date: 04/03/2017 10:54 pm
2.8 radiator
Date: 10/25/2019 04:10 pm
Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
FREE PARTS!!
Date: 01/10/2017 02:38 pm
  • Online today: 583
  • Guests: 404
  • Total: 404
4spd auto in a Pinto?
Started by crazyhorse, July 31, 2004, 05:58:55 PM
CHEAPRACER
You can get away with lower highway RPM overdrives with fuel injection. Lower speeds with a carb is ineficient and you loose a slight bit of low speed torque.
LOTS of work with very little reward. 2.3L Pintos are already geared so high that any thing but level country will cause a down shift from the tranie. And you want to add an overdrive to this!  You'll end up like my van, with a car that up-shifts / down-shifts at any and all elevation changes.   Spend your money on things that will help both power and mpg, like headers and a Ranger cam.   Play with the ignition timeing and curve.
ok I'm looking for more MPG& performance. so I'm loking at using an AOD trans in my "Lil Horse".  I know the bellhousing will be bigger, but will it fit w/out mods?  I can shorten the driveshaft no probs, IF the silly thing will mount relatively easily in my car. what I need to know is how far is the mount from the bellhousing? and is the bellhousing too big to fit in the trans tunnel?
