1980 hood needed
Date: 04/23/2020 10:41 pm
1974 Ford Pinto Squire Wagon
Date: 05/30/2020 01:51 pm
Pinto Runabout wanted
Date: 06/05/2018 04:42 pm
I need a 1976 hood
Date: 12/19/2016 06:02 pm
Date: 07/30/2020 11:45 am
1977 Pinto Hatchback Parts
Date: 08/29/2020 05:31 pm
76 drivers fender
Date: 07/20/2018 08:24 pm
74 4 spd and rear axle
Date: 09/26/2018 03:51 pm
'78 Pinto Windshield Trim
Date: 05/09/2017 10:46 am
  • Online today: 403
  • Guests: 232
  • Total: 232
351w Swap in 79' sedan
Started by 92jag, July 02, 2008, 01:44:16 AM
92jag
I ended up using an alt. and bracket and the lower v-belt pully off of a 302 I had sitting around. Now I just need to get an electric water pump. What is a good in-line fuel pump to use with a holley 750? I will add more pics of the car in a few days.
I used my stock Pinto alt w/ a v-belt, also relocated to the driver side but at the top of the motor. I made my brackets.
Welcome.
Looks like you will need to find a good donor or make your own brackets. You might need to get a different alt., maybe one designed for a v-belt (made to used as the tentioner) and use the serp. belt pulley on it. Keep in mind that if you swap to a v-belt the water pump will spin the wrong way.
When I relocated my alt. on my 302 Pinto, I located it low on the drivers side with home made brackets because that side had the head that was further back, but my rad. hose was on the other side.
92jag
and some more . . .
92jag
Hi all, my name is brian and I need some help finishing up my swap. My problems are what size inline fuel pump to use and how to relocate my alternator. I don't want to have an alt. sticking out the hood. See the pic. I am using a 94' 351w efi roller motor converted to carb with a c5 tranny. The motor has a 750 holley and torker II intake, and complete msd ignition with a 6al box.
Tell me what you think.
