Mallory Unilight dist 2.0
Date: 10/25/2019 03:44 pm
ENGINE COMPLETE 1971 PINTO
Date: 12/28/2017 03:55 pm
Date: 03/29/2019 07:20 am
Date: 02/04/2018 08:26 am
Date: 10/25/2019 03:30 pm
1978 RUNABOUT
Date: 04/01/2017 03:18 pm
Date: 08/13/2017 02:01 pm
Wagon hatch letters
Date: 12/31/2023 04:24 pm
Date: 08/02/2019 04:18 pm
  • Online today: 529
  • Guests: 464
  • Total: 464
Turbo Pinto pictures - finally
Started by Wittsend, June 29, 2008, 08:50:20 PM
Beautiful work, it's wonderful seeing clean, fresh reworks like these.
OK, second try (the last 10 minutes of work just crashed).  I had to repair the inner fender battery area due to rust. Since the battery has to be move I created a panel that works to the advantage of the turbo.  I was able to create the needed clearance for the big IHI turbo and the wastegate actuator. In fact, in one of the pictures you can see a small hole to the upper right of the motor mount. That's a drain hole for the depression I created for the wastegate control.  This also eliminates the exhaust bolt problem.
To my surprize I have been told that the '73 has a one year only steering rack (???). Anyway, it isn't conducive to to the swap. So, you can see I ground down a fair portion for clearance.
I slotted everything that relates to the engine and tranmission.  You can see the tranmission mount slots. Not shown are the front/back slots. I also slotted the up/down slots on the transmission to unibody mount. You have to remove the inserts that keep it from collapsing when bolted and reweld them to match the slot.  I even slotted the unibody as you can never have enough adjustment.
Well, I hope the pictures come through. And thanks everyone for getting me this far.
Tom
