Date: 04/10/2017 07:30 pm
1973 Pangra
Date: 01/06/2015 02:19 pm
Date: 10/10/2019 10:02 pm
Date: 07/17/2019 05:23 pm
Pinto brake booster needed
Date: 05/08/2021 09:00 am
Date: 05/15/2022 11:36 am
71 72 front bumper brackets
Date: 06/10/2020 10:55 am
Rear brake shoes
Date: 01/23/2017 05:01 pm
v8 springs
Date: 05/07/2017 04:46 pm
  • Online today: 367
  • Guests: 260
  • Total: 260
engine timeing
Started by woodie, June 27, 2008, 06:57:12 PM
I would use the bottom end timing numbers but I would retard a bit due to the compression increase....I would start at 4 BTDC...when increasing the compression it is not good to light the charge to soon otherwise your defeating the purpose of the increased compression. To find the optimum setting do a vacuum time and then add 1 degree advanced from there and leave it. Use hi-test or a mix of 50% regular and 50% e-85 ethanol.
10* BTDC seems to work well for me, gives you about 36* total advance.
woodie
 I,m mixing parts hear I have a 1980 bottom end and a D port open chamber head shaved 50.000 using a ranger rollercam . what timing numbers do I use ? the pinto bottom end the timing is 6btdc don,t know what the ranger is need something to get me in the ballpark thanks everyone
watch this
