1973 Pinto Wagon
Date: 05/06/2022 05:13 pm
1979 hatch needed
Date: 05/13/2018 08:52 pm
71-73 sway bar
Date: 06/12/2021 10:12 am
Date: 03/29/2019 07:20 am
73 Runabout
Date: 11/20/2017 03:19 pm
1980 PINTO for sale
Date: 06/19/2017 02:51 pm
Date: 11/12/2020 08:28 pm
Date: 08/13/2021 10:39 am
Clutch/brake pedal assemble
Date: 12/21/2017 11:26 am
  • Online today: 295
  • Guests: 206
  • Total: 206
Installing a headliner. Does the windshield need to come out?
Started by Smeed, June 27, 2008, 12:05:27 AM
I am 99% sure the headliner is folded around the lip.  To do it right you should fold it under the gasket lip.  I think you would be safe gluing it under the windshield gasket but I would not glue it around the rear window (if yours is a sedan) as you could have problems with it staying attached during the summer months.  The heat softening the adhesive and wind from driving with the windows down puts pressure in that area, making the headliner come free.  I glued a headliner in on my 67 mustang to save money but I was never happy with it so I redid it properly a few years later.  Headliners are pretty simple.  The key is having it warm when you do it as it will be difficult to get the wrinkles out otherwise.  Good luck
Smeed
Is the headliner just pushed under the windshield gasket or is it folded up and around it? I heard I would need to remove the windshield to install it correctly, but Im not really against just pushing it (neatly) under the gasket if its going to look and perform the same. Ive never done anything like a headliner installation before. While I was searching the forums for an answer I noticed a few other guys had. Is it something easy and straight forward or is it something I might want to leave to the pros?
The reason I ask is scheduled to be painted on july 11th and I thought that might be the time to have the windshield taken out so I can put in the liner?
'73 runabout
