I need a 1976 hood
Date: 12/19/2016 06:02 pm
Date: 04/06/2017 12:13 am
Date: 10/11/2019 11:13 am
Date: 11/29/2018 10:26 am
Date: 02/05/2020 11:06 am
Pinto brake booster needed
Date: 05/08/2021 09:00 am
Clutch Fork
Date: 03/31/2018 09:12 pm
79 pinto driveshaft
Date: 08/18/2018 02:03 pm
Deluxe Steering Wheel
Date: 10/16/2017 08:13 am
  • Online today: 600
  • Guests: 344
  • Total: 344
What is the "tank" under my front fender?
Started by popbumper, June 25, 2008, 04:41:51 PM
ilvmy76
The function of the Evap. canister, or charcoal canister, is to collect and temporarily store fuel vapors, from the vehicle's fuel tank and carburetor.
Later, during the normal running of the car, the system pulls the vapors out of this canister, and burns them.  That's what the attachment hose is for.
worry does not empty tomorrow of it's troubles, it emptys today of it's strength!
Thanks for the validation. Why the attachment to the air cleaner housing? What would the purpose be?
ilvmy76
It is an evap. cannister, mine is mounted in the same spot on my '76 MPG wagon,
non-AC, manual brake car.
Phil:
  AC compressor unit is on the passenger side BELOW the smog pump. It looks like a dealer add on (sorry, would not know any better) because the A/C controls are two knobs (one for speed, one for min/max) - in the middle of the dash next to the vent - as opposed to being in tandem with the standard fan and heater controls. NOTE: They look "official", as in "not sloppy", and the routing for all the hoses through the firewall are tidy, which makes me believe it's a dealer add on.
What side is the ac pump on? Passanger side   factory    Driver  dealer
based on my 76 bobcat  it would be the evaporator canaster and the vacuum canister is on the passenger side similar location.
Ladiesman 216
i believe its an evaporative fuel canister....used to control the amount of vapors in the gastank. Im not sure but i believe those fumes are sent to the air intake and burned through the exhaust.
Clear with a red top, mounted under the driver's side fender, hose from it to the air filter housing. Never saw one of these before. The car does not have power brakes, and the AC looks like a dealer or aftermarket add-on.
if your car is AC and PB this is a Vacuum canister. Most of these are on the passenger side and look like coffee cans.
But if its clear with a black top it might be a relocated charcoal canister.
Most of these were mounted on the front drivers side frame rail behind the radiator but I have seen them relocated to odd spots but the dealership to make clearance for accessories
FrankBoss
There is a wrapped hose exiting my air cleaner housing that goes up under my drivers' side fender, and if I look at the correct angle (when the door is open), I can see a plastic tank (looks like a windshield washer reservoir) tucked up under there, that the hose attaches to. BTW, the hose is ratty (has holes), so it's not doing much of anything, I suspect.
What is the tank for?
