Pangra wanted
Date: 02/05/2017 01:58 pm
Date: 02/18/2017 04:47 pm
Wanted 73 pinto squire wagon
Date: 05/09/2020 11:59 am
Date: 09/22/2020 11:33 pm
Date: 01/21/2023 04:19 pm
1978 Squire wagon 6 Cly
Date: 03/08/2021 10:44 am
Wanted - 71-73 Pinto grill
Date: 12/15/2016 03:32 pm
79 pinto small parts
Date: 04/24/2019 03:16 pm
78 fender and hood
Date: 03/23/2021 01:07 pm
  • Online today: 266
  • Guests: 274
  • Total: 274
Oil Filter
Started by c0rn_d0g, July 23, 2004, 03:20:21 PM
JEGS and SUMMIT both have then in their catalogs and on the net.
EAdams
Quote from: dick1172762 on August 04, 2004, 10:45:11 AM
Forget the kits! They use very small hoses and fittings. Use braded hose or Earls / Russall hose made for oil use. Its in the Jegs catalog in both black and blue colors. No smaller than #8 and #10 is better.
So what pieces are needed?  You have to have a piece to attach to the current location, the hose, and the piece you attach remotely.  Got a source for each?
EAdams
Quote from: c0rn_d0g on July 23, 2004, 03:20:21 PM
Is there anywhere i shouldnt mount a remote oil filter? example...does it have to be below the block, sideways, upside down. I'm looking for the best position and height to mount it. thanks.
What remote kit did you get?  From where?  I need one myself for my 1600cc engine.
On our race cars that I build, I have mounted the filter everwhere except out side the car, with NO difference in pressure or flow. I have run the car and moved the filter from ground level to hood level with no difference in the pressure. Put it where it fits and you can get to it to change it. I use the inter fender panel, about valve cover high to mount mine. Make sure the hood will close first.
c0rn_d0g
