Date: 04/20/2017 10:10 am
Date: 12/09/2018 11:35 pm
1975 Ford Pinto
Date: 01/13/2020 11:02 am
Date: 11/08/2020 02:10 pm
1972 Rallye wagon rebuild
Date: 11/14/2020 07:31 pm
Date: 10/28/2018 08:45 am
A.c. alternator hrackets
Date: 09/03/2017 12:11 pm
1978 pinto grill
Date: 07/24/2018 02:18 pm
76 drivers fender
Date: 07/20/2018 08:24 pm
  • Online today: 1,459
  • Guests: 85
  • Total: 85
2.3 in a '73 The Fun Stops... HERE!
Started by Wittsend, June 16, 2008, 08:13:03 PM
when we did the swap into my dads 73 we installed the engine and tranny together, mounted the tranny to the crossmember and leveled the engine from there. than welded the mounts. went well but had to recess the radiator forward of its factory spot which meant notching the support.
Here are a couple pictures of my 73.  One picture is of the pass side motor mount.  I was not able to get a good picture of the drivers side mount.
Hum, I only heard about the '71-'73 and '74 - up changes in the suspension. But, I guess there is something new to learn every day.
I played around with it somemore and things seem better.  I was able to slide the radiator in and have about 1-1/4" to the pulley.  That is actually a lot better then my Sunbeam Tiger.  I also found that I had the engine slanted a bit and that was causing some of the pan/rack clearance issues.  Regardless I took off as much as I could on the larger end of the rack.  This gave me 3/16" to 1/4" more clearance.
The big pain is feeling ready to "commit" to welding in the frame mounts - because it is such a permanent matter.  Those who are '74 - up just, "plant them where you see them." How nice.
Tomorrow I'll bring the T-5 into the equation and see how it all goes.
Tom
I did not do the 2.3T swap on my 73 but I do know a little on what was done.  My friend that did the conversion, ended up using a 72 rack from his other car to gain more clearance for the pan.  I am not sure what all the swap entailed but it gave him the clearance he needed.  I also want to say that he needed to swap some of the suspension as well because the 73 is an odd duck.
OK, I thought I was following all the advice that I could find.  I've asked a million questions, I read a million previous posts. Yet it seems like my 2.3 Turbo (88 from a T/C) won't fit my '73 Pinto Wagon.  This is where I'm at:
1. I read that I should put the upper, rear frame mounts (for the engine) in the upper forward bolt hole.
Results:
A. The frame rail bolts holes on the driver's side are about 1-1/2" back of the passenger side (roughly 17" vs 18-1/2"). So that concept doesn't work. At least on the drivers side.
B.   When I try and get the passenger side lined up to the said bolt holes the oil pan (driver's side) hits the large end of the steering rack tapered aluminum piece.   I've filed this down, but it still seems like an issue.  I have also dimpled the oil pan in this area. I can only go so far before I'm filing the flat area of the hold down strap. Have others experienced this?
C. It seems like the best way I can get adequate clearance at the rack is to move the frame rail mount forward until they hit the sway bar mounts (as a stop).  The only two set of pictures I could find did not have a swaybar for comparison. But this seems pretty far forward too me. It is close to 1/2"  forward of just using the stock hole location.
D. This still seems to have the engine rather high, but it is as low as I can go.  This also seems to put the front pulley into the radiator area.
Summary:  My attempt to get the engine as low and as far back as I can (for hood and radiator clearance) seems to be hampered by the steering rack's large end. Any thoughts, comments (other than start with a '74 and up car)?
