Wheel cap
Date: 04/25/2022 11:21 pm
Date: 02/28/2018 09:18 am
Date: 09/12/2018 12:33 pm
1971-1975 Pinto
Date: 01/09/2017 04:14 pm
Bumpers
Date: 07/06/2018 04:47 pm
1973 Interior parts wanted
Date: 01/02/2017 11:02 pm
Date: 10/28/2018 08:45 am
1971 Pinto
Date: 03/04/2017 11:28 pm
Wanted 71-73 Pinto grill
Date: 03/09/2019 10:45 pm
  • Online today: 624
  • Guests: 560
  • Total: 560
valve sticking
Started by krazi, June 14, 2008, 06:02:12 PM
yeah did the valves when i replaced the valve cover gaskets. figured that i would get that done since i had to take em off anyways. so i really cant orient where the noise comes from.
Starliner
I believe these engines had mechanical lifters.   So regular valve adjustments are required.
Have you performed a valve adjustment recently?   I would suggest you do that and inspect everything at the same time.
With solid lifters a little top end ticking is acceptable.
1973 Pinto 1600 - Sold!
1979 Pinto 2300 - Sold!
hmm, mine is a 75 and i seem to have the same issue, but i have more than 300-400k on the motor. im not even sure what it is.
krazi
I have a 77 bobcat with a 2.8 in it. while running, I can hear what sounds like metal to metal contact. its not consistent enough to be a rod bearing, and it seems to be comming from the top part of the engine. it has the aluminum cam gear, and about 10,000 on new head gaskets. what could it be?
krazi
yeah, I'm Krazi!
