Need Brakes for 1971 Pinto
Date: 04/27/2018 11:48 pm
Date: 11/14/2019 04:02 am
Date: 02/14/2018 01:34 am
1976 Ford Pinto Pony
Date: 09/06/2018 05:40 pm
Date: 07/30/2020 11:45 am
Date: 05/22/2018 01:54 pm
Various Pinto stuff for sale.
Date: 11/21/2018 01:56 pm
71 72 front bumper brackets
Date: 06/10/2020 10:55 am
Date: 09/26/2019 05:31 pm
  • Online today: 267
  • Guests: 265
  • Total: 265
cooling fan
Started by wedge446, June 04, 2008, 07:46:38 PM
wedge446
All the ranger pumps I`m finding are cast iron, maybe I should look at a mustang pump(if that matters)
I did sit the pinto & ranger pump side by side and the only thing different is the rangers pump has the pilot shaft turned down smaller at the end..
If I have to buy a new pump it will be aluminum.
Thanks
apintonut
sorry i should have remembered to mention that but the ranger one come in aluminum too. if u look around. it only saves about 1 lb but hay that on less pound.
74 hatch soon to be turbo 2.3
73 sedan soon to be painted
stiletto parts(4 sale)
79 pinto wagon & beentoad
wedge446
An update for people wanting to do this..
I got a fan/clutch from a 90 ford ranger and it look like it will work good on there (BTW, there are 2 fan sizes small & big) Either one will work fine...
Here it comes, BUT!  the pilot shaft on a pinto water pump is to big to fit the ranger fan clutch, the water pump needs to be changed to a ranger pump for it to work($45)...It kinda sux seeing that I just installed a new water pump on the pinto 2 months ago..
Anyone want to buy a used water pump?
wedge446
Thanks, thats just the info I needed.
apintonut
just go to ur parts store and look for a 90 ranger clutch. u will need a fan for that same app.  it going to be about 60$
wedge446
I`m thinking of going with a viscous style cooling fan in place of the direct drive it has.. I don`t want an ele. fan
I`ve found in racing that a viscous type fan clutch works really good when wanting to free up some power but still move the air when needed..
I`m after MPG
Is there a bolt on viscous fan & fan clutch for the pinto?
