Looking for front seats
Date: 08/10/2021 09:54 pm
Clutch Cable Needed
Date: 04/03/2017 11:03 pm
77 pinto cruz. wagon
Date: 06/15/2017 09:18 pm
2 Pinto Wagons for Sale
Date: 10/29/2018 02:02 pm
Brake rotors
Date: 03/24/2017 09:02 pm
Date: 10/31/2018 12:04 pm
SEARCHING HOPELESSLY
Date: 02/02/2017 07:21 am
Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
Date: 08/26/2018 06:35 pm
  • Online today: 529
  • Guests: 289
  • Total: 289
Electric Fan
Started by pbean09, June 03, 2008, 09:46:56 PM
Do you have a temp. guage?
pbean09
I have a V-6 2.8L out of a 75 mustang.  it doesn't boil over but It's not far from it.
Are you absolutely sure the problem is the fan, or lack of a shroud?
A stock set up works very well if all the components are functioning properly.
What do you have for an engine? Is it stock? is the radiator in GOOD condition? Is the t-stat working?
By "overheating" do you mean that it 'boils-over' or does the engine light come on (or a gauge indication)?
Please keep in mind that the factory sending unit and or gauge are not all that accurate.
Not knowing what you have for an engine, or if you have an A/C car it is hard to say what you should do.
If you are having a problem, your best bet is to get a shroud, a 5 blade fan, or a bigger radiatior.
ADDED: Another thing you can do is install a taller spacer to move the fan closer to the radiatior.
pbean09
The reason I want one is because their isn't a shroud on the mech. one in the car and in town it wil tend to get little over heated. What fan do you think would be easiest to put in.
I have installed them in a couple of my Pintos. They are not hard to do as most come with the zip-ties to mount them on the radiator. You have to decide if you want one that comes on automaticly, a full manual one, or one that will let you do both.
My question back to you is why do you want to do this?
Some people remove the stock one to get more power from the engine(like me), others install them because they think that electric ones just cool better.
Mechanical fans, like the stock ones bolted to the waterpump, provide the best airflow.
Most electric fans do a better job 'pulling' than they do 'pushing'.
The fan is very important to the survival of your engine, this might not be an item to 'cut-corners' with.
Keep these details in mind when you buy one.
pbean09
I know someone has put an electric fan in their pinto so come on and spill the beans.
pbean09
I'm looking for an electric fan to put in the Bean and was wondering what is the best setup y"all have found? What is the easy install.
