1974 Ford Pinto Squire Wagon
Date: 05/30/2020 01:51 pm
72 Pinto
Date: 03/07/2019 12:07 pm
Date: 11/11/2019 04:49 pm
Date: 10/11/2019 11:13 am
Date: 07/01/2019 03:17 pm
Date: 05/15/2022 11:36 am
Need Clutch & Brake Pedal
Date: 12/23/2016 06:16 pm
1980 Ford AM radio
Date: 12/22/2019 11:57 am
Drip rail chrome
Date: 01/14/2017 09:18 am
  • Online today: 295
  • Guests: 174
  • Total: 174
Rack and Pinion Bellows
Started by 77pintocw, June 01, 2008, 09:24:05 AM
wedge446
Just use any good chassis grease(same as you use greasing a ball joint or tie rod end)
You use a needle greaser to inject the grease into the bellow then use RTV sealer to seal the hole made by the needle greaser.
You should be able to find a needle grease at your local auto parts store.
Hope this helps.
77pintocw
Hi Folks:
I have to replace one of the bellows on my rack and pinion steering on my '77 CW.  I have two questions, what lubricant do you use to fill the bellows and how do you inject the lubricant into the bellows?
Thanks for your help.
77pintocw
1977, Pinto Cruising Wagon, White with Blue Graphics
