Date: 04/30/2023 04:31 pm
Date: 04/13/2018 11:30 am
oldskool787
Date: 02/12/2017 12:42 pm
Need Brakes for 1971 Pinto
Date: 04/27/2018 11:48 pm
72 Pinto Wagon for sale
Date: 12/31/2017 08:40 pm
71 72 front bumper brackets
Date: 06/10/2020 10:55 am
80 pinto original
Date: 08/04/2019 10:45 am
Date: 07/08/2017 08:25 pm
Date: 08/09/2018 07:49 am
  • Online today: 1,459
  • Guests: 792
  • Total: 792
Clutch Dilemma
Started by Wittsend, May 31, 2008, 12:29:34 AM
Hi Tom, if you want I can mail you picture's of my self contained bolt anywhere master. hyd. clutch unit, 2 hook up's simple hyd. line and stock pinto clutch cable, youre done. Fred   :)
apintonut
bill has answered this many times
http://www.fordpinto.com/smf/index.php/topic,3008.0.html
how ever i do have a bell out of a mustang that was a bolt in! no mods.
earthquak got the trany and ran the numbers so he knows what year it was out of.
74 hatch soon to be turbo 2.3
73 sedan soon to be painted
stiletto parts(4 sale)
79 pinto wagon & beentoad
Well..., Project Turbo Pinto is hit it's first wall.  The T/C has a hydraulic setup.  Thus, the clutch actuates by pushing it back.  The standard Pinto setup is cable and actuates by pulling forward.  By virtue of how each system works the clutch fork pivot points are on opposite sides of input shaft.
The last thing I want to do is hunt up, pull out and pay for a "proper" bellhousing. My concern is NOT "how I will fasten the cable to the bellhousing," I have a number of ideas to accomplish that. So, getting a correct bellhousing for that reason is not important to me. My concern is the mechanical leverage aspects of the pivot point as it relates to the longer, cable style clutch fork and the shorter hydraulic style clutch fork.  So:
1. Does anyone know if the T/C, T-5 bellhousing has a threaded boss (for the pivot ball) on the opposite side of the input shaft to use with a cable type fork?  This way I would only have to replace the fork.
2. Or, does anyone know if the closer pivot point on the hydraulic system fork  provides enough leverage to work with a cable?  It seems the possibility exists that the pedal effort may be too high.  The reason I ask is that I was contemplating using a longer cable and just pulling the exists setup from behind - if the leverage is appropriate.  This method only requires adapting a longer cable.
I would appreciate any input.  Keep in mind I'm cheap and I like to fabricate.
Thanks, Tom
