1980 cruising wagon ralley
Date: 07/12/2019 01:41 pm
1974 Ford Pinto Squire Wagon
Date: 05/30/2020 01:51 pm
1971 Pinto 5.0L
Date: 12/02/2017 12:23 am
Date: 12/31/2017 09:03 pm
1978 Squire wagon 6 Cly
Date: 03/08/2021 10:44 am
Date: 08/06/2021 02:23 pm
73 rear hatchback glass
Date: 07/06/2017 11:33 am
Bumpers
Date: 07/06/2018 04:47 pm
1971-1975 Pinto
Date: 01/09/2017 04:14 pm
  • Online today: 535
  • Guests: 428
  • Total: 428
V8 Pinto questions
Started by Twister_Reject, May 25, 2008, 12:12:05 PM
92jag
I am using a c-5 out of a mercury Capri. It just requires a bit of work with a bfh on the fire wall. I also used the stock tranny mount.
Hey Twister, not sure what year your car is, I am posting a step by step swap on my "71. Trying to put as much info as possible to help others. Take a look under "'71 V8 swap-let the fun begin"
lil haus
You need to find a C-4 trans out of a Cobra V-8 Mustang II  it has a smaller bellhousing and torque converter w/this set up you dont have to cut the firewall & floor to fit you just have to bend the pinch weld down where the tunnel meets the firewall
Twister_Reject
So 9" it is, thanks for the heads up. How hard is it to get a c4 in there?
Twister_Reject
Well after a long debate I have decided to go with a V8 instead of a restore. The reason I got the car was because it reminded me of my Poison Pinto Hot Wheel I had as a kid. So now I'm going to build my Poison Pinto. I bought a '68 289 with a 3 speed. I plan on a wild 289 backed with a 4-speed. I am also thinking 9" rear. I know it can be done, but a little advice never hurt a guy, right? I read through this site that a 8" works great, so my first question is what size meats can I stuff in the rear using a bolt up 8" rear? Also when it comes to engine/tranny mounts I have not a clue. The car has a V6 and a 4 speed out of a '75 mustang II. Can I use those mounts for anything? Any advice, pointers, or answers would helpful to me.
