Date: 10/02/2017 02:16 pm
77 Cruising Wagon Front Seats
Date: 04/12/2017 12:37 pm
Weber dcoe intake 2.0
Date: 08/01/2018 01:09 pm
Mustang II V8 swap parts
Date: 03/26/2017 02:25 pm
Date: 03/25/2019 09:02 pm
73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
Seeking 1971-1973 Rotors
Date: 04/08/2021 12:23 pm
Date: 07/20/2018 03:00 pm
Date: 02/26/2017 03:22 pm
  • Online today: 2,670
  • Guests: 557
  • Total: 557
Merkur Harness HELP!
Started by vbpinto, May 23, 2008, 06:20:09 PM
I have no experience with the Merkur harness but the following links may help you start to figure it out.  If you are not using the Merkur computer, you may also need to rearrange some of the wires at the computer connector.
http://www.gt350mustang.com/eecspecsturbo.htm
http://www.blindchickenracing.com/how_to/t-bird_install/t-birdwiring.jpg
skunky56
Try this guy wwwrapidogroup.com  hope this helps.
77 Starsky/Hutch 2.3 Turbo A4OD Sunroof
78 Wagon V6 C3
vbpinto
I have everytihng mocked up dangling in the engine bay so i can test and hear it run, before i go installing the harness and lengthening and shortening wires as needed. I have fuel pump operational, injectors are firing, but no coil power or spark.  Is there wires from the pinto harness i need to splice in??? i have hooked everything up from the merkur harness just as it came out. All of the power and grounds. There is 2 connectors that i couldnt hook up, one under the dash that was brown and square. also one that hooked up on driver side fenderwell in the engine compartment. Any ideas???
