Clutch/brake pedal assemble
Date: 12/21/2017 11:26 am
1980 Pinto for sale
Date: 11/24/2016 06:32 pm
'79 Ford Pinto, Green,
Date: 10/29/2019 11:50 am
front end parts
Date: 03/30/2018 12:48 pm
74 hood
Date: 07/03/2017 03:46 pm
76 drivers fender
Date: 07/20/2018 08:24 pm
Date: 08/13/2021 10:39 am
1971 Pinto (survivor)
Date: 05/15/2022 04:42 pm
  • Online today: 2,670
  • Guests: 515
  • Total: 515
what year hatch will fit my 78 pinto hb?
Started by neil m, May 20, 2008, 04:04:19 AM
IIRC: Any metal framed Pinto or Bobcat hatch will bolt up to your car, but the early ones have different lift supports. The issue with a Bobcat one is that the emblems will not interchange. Keep in mind that you will be less likely to find a Bobcat one due to lower production numbers.
You could also swap to an All Glass Hatch, but you will need not only the glass, but the hinges, handle, seal, corner trim inserts, and lower bracket that would need to be welded to the car. Also, just as a note for other reader, if the car is a PRE-77, you will need to do some cutting to fit the corner inserts.
neil m
Hi all does anyone know if a 1980 hatch off a mercury bobcat will fit my 1978 pinto? it looks the same but if someone knows for sure i would appreciate the info. thanks Neil
loving anything with the blue oval
