Date: 09/12/2018 12:33 pm
1971 Pinto Parting out
Date: 07/06/2018 01:11 pm
1976 Squire wagon
Date: 09/12/2018 10:30 pm
1972 pinto grill
Date: 02/27/2018 12:13 am
Date: 09/01/2017 11:58 am
Date: 06/07/2021 08:14 pm
Date: 03/17/2019 03:57 am
Date: 08/09/2018 11:09 am
72 PINTO WAGON
Date: 09/23/2018 06:16 pm
  • Online today: 267
  • Guests: 378
  • Total: 378
Axle Bearings for 72 the same as other years?
Started by TIGGER, May 11, 2008, 12:35:57 AM
I know these guys can help you if you strike out at NAPA.
http://www.kanter.com/
Hey TIGGER,
They should be looking in the BRAKE section NOT the driveline section.
The BIG BLUE FORD book shows 2 different part numbers the second number starts at 1974.
It took two guys looking for 20 min but I think I got the right bearing.  According to the book these guys used the bearing is the same for all years for the 6 3/4.  l will find out for sure tomorrow when I go to my friends shop to install it.
Thanks PIntony, I will be heading to Napa shortly.
BTW the bearing changed in 1974, so only the 71-73 will work.
Hey TIGGER,
RWP30YYR TIMKEN Ball Bearing.
Maybe you could find a good axle and swap the bearing and axle??
One of the axle bearings is making noise at freeway speeds.  I pulled the acle from my 79 Bobcat parts car thinking I could just swap it.  The axles are different.  The early axle have less splines.  So I went calling around for a new bearing and nobody had a listing for one.  The bearing from the bobcat looks the same but I am not sure about the ID.  Pintony, maybe you can answer this for me?  Will other year axle bearing work?
