Date: 11/11/2019 04:49 pm
73 rear hatchback glass
Date: 07/06/2017 11:33 am
SOME PARTS FOR SALE
Date: 01/11/2017 10:45 am
Date: 10/01/2020 02:00 pm
Date: 11/29/2018 10:26 am
pro stock front end
Date: 06/28/2019 07:43 pm
Mustang II C4 Transmission
Date: 07/28/2017 06:26 am
Wanted 1973 Ford right fender
Date: 06/03/2017 08:50 pm
Date: 03/18/2020 01:30 am
  • Online today: 344
  • Guests: 153
  • Total: 153
Replacing upper and lower ball joints in my '78 wagon??
Started by ADaughen, May 08, 2008, 05:15:43 PM
ADaughen
Quote from: FCANON on May 08, 2008, 05:25:44 PM
From the factory they came with rivits..mustang 2 and pinto.. you remove the rivits with a cold chisel and the new Ball joints come with bolts...
FrankBoss
www.PintoWorks.com
Awesome!
Thanks.
I didn't want to take the old ones off before figuring what I was doing.
Original ball joints... Impressive.  The car *only* had 288k on it when I parked her.   ;D
BTW, Does anyone know what size bolt is used for the lower shock mount?  Mine is frozen solid inside the sleeve.  No amount of penetrating fluid, heating or beating is breaking it loose.
'78 Cruisin' Wagon
FrankBoss
www.PintoWorks.com
ADaughen
Ok, so I see two types of ball joints, if I search google, press in and screw in.
Looking at mine, they look like HUGE rivets.  I can't pull them out or unscrew them.   ???  The MII ball joints I found have three bolts and nuts that drop through the same holes that are solid in mine.
I was hoping to get my front end done but I keep finding more stuff to work on.
Any help would be appreciative.
Thanks,
Adam
'78 Cruisin' Wagon
