Date: 07/20/2017 01:23 am
$300 Pinto for sale
Date: 04/19/2017 10:24 am
Need Clutch & Brake Pedal
Date: 12/23/2016 06:16 pm
1977 Cruiser
Date: 06/29/2019 06:28 am
1979 hatch needed
Date: 05/13/2018 08:52 pm
1972 Pinto for sale
Date: 05/19/2021 12:41 am
Front sway bar frame brackets
Date: 07/13/2017 01:05 am
Hoard of Pinto parts
Date: 12/17/2016 04:14 pm
Date: 09/01/2017 11:58 am
  • Online today: 427
  • Guests: 401
  • Total: 401
C4 Swap
Started by WVBobcat77, July 14, 2004, 02:50:22 AM
WVBobcat77
That must be it then, cause I had to get 3 1/2 in. cut out of the drive shaft for it to work.  I've been looking at shifters, but I can't find one I like.  They all look too much like race car shifters.  Wonder if I could adapt a shft cable to the stock shifter?
Bill in WV
1977 Bobcat
1978 Pinto - V6 Sedan
i opened up my crossmember holes a bit, cut off the kickdown lever and use a cable operated B&M ratchet shifter '83 was the first year for the C5 but in '82 they used both C4 and C5 trannys. The C5 bellhousing is longer for the added size of the lock up torque convertor, i have a C5 with a C4 bell and a C4 non lock up convertor
Killer74
you could have put it in backwards, the mount holes maybe offset a little.
*74 Turbo 2.3 Pinto
*77 351w Turbo Pinto (still in the works)
WVBobcat77
It very well could be a C5 came out of an 82 mustang.  It looks identicle to a C4 though.  I din't have a 4 speed I had a C3.  Could I have put the cross member in backwards?
BTW:  Thanks for helping out, I was beginning to think nobody cared.. :)
Bill in WV
1977 Bobcat
Killer74
hmm...are you sure you got a C-4 and not a C-5?
The tail shaft should point straight back. Sounds like you have crossmember issues. The stock 4 speed member might need to be modified (if it'll work at all) to get the tranny pointing the right way. This should fix your shift lever problem too.
*74 Turbo 2.3 Pinto
WVBobcat77
Yep, still doesn't help me with my problem. ::)
I am just a good ol' country boy, allbeit a pretty well educated one.  I done went and gradiated 8th grade, Hyuk, Hyuk, Hyuk!!!!
Now, back to the problem.  Surely some of you master mechanics out there can address this for me.
Bill in WV
1977 Bobcat
losin sux
Caterwampused ......now THAT is a good ol country boy term!
77 HB 2.3 C3 3.40
WVBobcat77
Come on guys,
No idea's what might be going on with this?
Bill in WV
1977 Bobcat
WVBobcat77
I hope someone can answer this :-\.  I swapped in a C4 out of an 82 Mustang into my 77 Bobcat.  Now the shift detent lever on the case will not go all the way to PARK.  It hits on the trans tunnell.  Also the vibration damper points more to the drivers side where before it pointed straight back.  Have I put the Crossmember in backwards or is something else caterwampused?  ??? ??? ???
Bill in WV
1977 Bobcat
