72 PINTO WAGON
Date: 09/23/2018 06:16 pm
Need 72 pinto parts!
Date: 06/14/2019 01:40 pm
Date: 04/20/2017 08:56 pm
Date: 01/06/2017 11:42 pm
78 windshield trim
Date: 02/01/2020 08:46 am
Date: 07/20/2018 03:00 pm
Date: 02/18/2017 04:47 pm
Date: 10/24/2019 01:45 pm
1980 hood needed
Date: 04/23/2020 10:41 pm
  • Online today: 489
  • Guests: 207
  • Total: 207
C4 Converters????
Started by licketysplit, April 28, 2008, 01:03:45 AM
Mornblade
Quote from: CHEAPRACER on April 29, 2008, 10:38:36 PM
That's probably for the v-8 which is not interchangeable with the 4 cyl. (different alignment hole size for starters) More than likely you will have to spend some money and have your converter opened up and modified.
And THAT is why I kept the old converter until after we were ready to install everything.  I wanted to make sure that it would work properly in the application... if it doesn't, I'll have to sell off the new one.
I'll let you know in a few months when we are ready to put everything back together.
CHEAPRACER
Quote from: Mornblade on April 29, 2008, 02:12:35 AM
The one I picked up was from Summit and their part number is "TCI-450700".  That's the converter for the case-fill C-4 1970-1982 with a 2000rpm stall speed.
There is only a $6 difference in price between that one and the pan fill version.
licketysplit
Thanks guys for the replys. I have the stock 2000 converter that came in the car. The car is a 1973 that came with a 2000 and a C4, I rebuilt the C4 and iam converting the car over to a 2300. Hmm, maybe i need a 1600 C4 converter? He He.........
bobscat
Quote from: Wittsend on April 28, 2008, 11:57:02 PM
From my understanding the reverse is true with most "stock" convertors.  That being the less power an engine has the higher the stall speed to prevent bogging the car. So, a V-6 convertor probably would have a lower stall speed than a 4 cylinder. But, there might not even be any difference between the two (at least that you would notice).
I don't claim to be an expert so anyone please chime in.  My recollection was from years ago when V-8 cars would use 6 cylinder convertors for better launch.
Tom
Yes, this is true, as I ran a v6 converter in my 302-c4 set up for just the same reason.  A little higher stall, but not overly expensive since it is a stock part.
Mornblade
Tom
licketysplit
Well $200 isn't per say breaking the bank! Whats the part number on the converter? As for the V6 converter, i maybe wrong on this but with the V6 having more tork then the 4 cly it should give a higher stall then the 2,300 converter? As i see it the V6 converter would have to stall higher? How much you asking for the V6 converter with shipping to Bakersfield Ca. 93307? Thanks, Howard
Hi Howard, I have a 78 v-6 converter if that will do you anything. Fred   ???   :)
Mornblade
I'm not sure about the T-bird converters, but I just bought a TCI Saturday Night Special converter with a 2000 stall for $200.  I'm not sure if you consider that to be breaking the bank or not.
licketysplit
I am building a 1973 pinto that i converted to a 2,300 with a C4 trans. I would like to find a little bit higher then stock stall speed converter without breaking the bank! Would a V6 converter from a 83 or 84 T bird with a C4 trans work to rise the stall speed? Any help? Thanks Howard
