Date: 01/24/2021 07:54 pm
Date: 04/13/2017 04:56 am
Date: 04/30/2023 04:31 pm
77 Wagon rear hatch
Date: 12/04/2019 05:57 am
Date: 01/28/2021 03:49 pm
Wagon hatch letters
Date: 12/31/2023 04:24 pm
Date: 08/22/2017 09:21 pm
1971 Pinto
Date: 03/04/2017 11:28 pm
Date: 09/20/2018 11:01 pm
  • Online today: 600
  • Guests: 384
  • Total: 384
mustang turbine/hurricane wheels
Started by dholvrsn, April 24, 2008, 11:50:56 AM
skunky56
Thanks Tigger,  yes I did install longer studs on the front rotors, 3" Moroso.
77 Starsky/Hutch 2.3 Turbo A4OD Sunroof
78 Wagon V6 C3
Quote from: skunky56 on January 07, 2010, 02:49:44 PM
This is my wagon with 1/2" spacer no rubbing the inner fender well when in full lock, no hitting the UBJ.
Paul
Looks good.  I assume that is your 78? Did you have to install longer studs with the spacers?
16" wheels off a '88 turbo coupe with 225-60-16" tires rubbed on the front part of the leaf springs.  Also had some rubbing on the passenger front of the wheel well.
I manipulated the wheel well lip.  I used washers (I know not the best) to space the wheels out about 3/16". I only used them short term.  Frankly I would never recommend the 16" wheels (Ford) on the Pinto.  General it requires a low profile tire that looks too "Ricer" (to me) and the suspension really isn't optimized for such a tire.
15" in a 195-205 60 series might work and look good.
Tom
skunky56
Paul
78 Wagon V6 C3
apintonut
i ground a 1/8 out of the top a arm and i was ruff on that car and never had any problem's
74 hatch soon to be turbo 2.3
73 sedan soon to be painted
stiletto parts(4 sale)
79 pinto wagon & beentoad
Would 1/4" spacers be thick enough? I got a couple of them hanging on a nail on the wall (along with the rag joint that I had two years and still haven't installed...). 10mm?
Thanks!
skunky56
1/2 " spacers on front none on rear, I have the 10 hole fox body wheels with 225/50r15 no rubbing at all
78 Wagon V6 C3
I see  a few pictures of Pintos with '80s Mustang turbine/hurricane wheels on them.
How do you manage it without rubbing the upper A-arm? Thanks!
