1971 Pinto Parting out
Date: 07/06/2018 01:11 pm
2.3 front sump oil pan
Date: 07/24/2018 03:17 pm
79 Wagon with many extras
Date: 07/08/2020 04:18 pm
74 Wagon Interior
Date: 01/22/2017 06:38 pm
Date: 03/18/2020 01:30 am
Date: 02/27/2017 10:10 pm
Radiator
Date: 05/27/2018 06:07 am
1971-1975 Pinto
Date: 01/09/2017 04:14 pm
76 Pinto Wagon
Date: 07/08/2020 05:44 pm
  • Online today: 489
  • Guests: 160
  • Total: 160
Pinto questions
Started by ADaughen, April 18, 2008, 11:56:40 AM
ADaughen
DHOT!
'06 Mustang V6 wheels do NOT fit 11" Granada rotors.   :(  The hat is too thick / the wheel has a small lip to hold the center cap.
I'm going to cry.
Does anyone know where I can get the hats turned down ~1-1.5mm?  Preferably Dayton-Area.
'78 Cruisin' Wagon
ADaughen
Well, I picked the 11" rotors.
They came in the mail yesterday, along with calipers and brackets.   ;D
I still need to get over to AutoZone to get a ball joint remover and figure out what springs I need to order for the bigger engine.
'78 Cruisin' Wagon
ADaughen
Alright... so since I'm taking the spindles off and UCA/LCAs off to get cleaned up what springs and shocks should I be using for a 302 transplant?
I tried looking in the FAQ, but didn't find anything.   :'(
'78 Cruisin' Wagon
ADaughen
Here's a sneak peek:
I took off the pin stripe and door moldings (hence the white stripes).
Hood just got the three stripes ground off it.  It looks like it has been "tweaked" in an accident.  There was about 1/2" deep bondo where it starts to curve down.  It was bad enough it started cracking in spots.  I'm going to get it reshaped properly, hopefully.
I'm just trying to decide 9" or 11" rotors on the front.  :D
'78 Cruisin' Wagon
ADaughen
It looks like I may do that for now...
This is going to be crazy when it gets done, though.  The four link would finish it up just right.   ;)
'78 Cruisin' Wagon
COBRAII
[quote author=ADaughen l
I *think* I want to do a 4-link.  I'm not sure though.   :-\
The plan is to have it streetable, but able to run some hard launches at the strip every now and again.
I know there is a lot of geometry in rear ends and before I start ripping the old stuff out, I wondered if there was a "right way" vs my "easy way".
[/quote] Go  with the leafs, plenty of  fast cars hooking with them.  The biggest concern would be getting your pinion angle right when you weld the spring pads on. Traction bars may not be as exotic, but they work :)
I used the leaf springs to do the install, thats why I am selling the arms.
BTW: All 8 bolts slid right out when I unbolted them.
ADaughen
Do you have photos of how it was set up?
I might take you up on that offer for the bars...
'78 Cruisin' Wagon
I have the four arms from my last donor. $20. + shipping.
I installed my 7.5" Trac-Loc in my Pinto.
ADaughen
I have a partially stripped 8.8" rear.  Someone's project part they discarded.
I want to remove the stock rear and put this one in it's place.
'78 Cruisin' Wagon
