1974 Wiring diagram free
Date: 10/27/2019 06:56 pm
Date: 01/28/2017 12:30 pm
1971-73 2.0 motor moiunts
Date: 05/17/2024 09:18 pm
72 Pinto
Date: 03/07/2019 12:07 pm
Date: 01/28/2021 03:49 pm
Hood Hinge rubber boots
Date: 09/28/2018 05:49 pm
1974 Ford Pinto Squire Wagon
Date: 05/30/2020 01:51 pm
Need Interior Panels
Date: 07/09/2018 04:59 pm
2 Station Wagons for sale
Date: 04/20/2018 11:10 am
  • Online today: 529
  • Guests: 452
  • Total: 452
door data plate
Started by pintoman, July 08, 2004, 05:13:16 PM
Poison Pinto
QuoteDoor codes are worthless for finding out gear ratios.
Well, both my Pintos were right on, so I wouldn't necessarily say "worthless." For those into numbers/code-abiding restorations, they're far from worthless.
However, the more accurate way to know what is actually in the vehicle is to look at the metal tag on the rear end itself (which both you and I suggest). Even so, the internals could have been swapped.
Short of removing the cover, I'd go with the tag unless/until you notice a disparity.
CHEAPRACER
Door codes are worthless for finding out gear ratios. Mine said 3:18's and it had 3:40's. The tag on my '74 was located right on the rear axle cover bolt. After removing my cover, the rear tag was correct.
pintoman
     THANKS FOR THE INFO.NOW I CAN ADDRESS THE SPEEDO GEAR PROBLEM SO I CAN HAVE A FAIRLY ACCURATE SPEEDOMETER.
Poison Pinto
It's a 3.08.
You can download and run my VIN/Data decoder (found in the FAQ threads on this site).
Also, your tranny should have a metal tag on it. Use a cloth with a little gasoline on it to clean the tag off so you can read it. On this tag will be several codes. On the lower edge, starting at the left, should be the following:
3     08
That's the ratio of the rear end.
pintoman
     I HAVE AN 80 RALLYE. I NEED TO FIND OUT WHAT THE REAR END IS.I THINK IT IS EITHER A 3.08 OR A 3.18.THE DOOR CODE IS A Y.ANY HELP IS APRETIATED.
