Pinto Watch
Date: 06/22/2019 07:12 pm
cam pulley
Date: 05/30/2018 04:56 pm
Date: 07/03/2025 04:35 pm
Date: 04/12/2017 08:15 am
Date: 02/08/2018 02:26 pm
Clutch Cable Needed
Date: 04/03/2017 11:03 pm
Date: 10/28/2018 08:45 am
1973 Pangra
Date: 01/06/2015 02:19 pm
cam pulley
  • Online today: 128
  • Guests: 90
  • Total: 90
71 V8 swap-let the fun begin!!
Started by 71pintoracer, April 16, 2008, 09:25:18 PM
bobscat
Hey, I brought the pictures with me today, so I will be emailing them to you.  If anyone else has any inquiries on this subject, let me know and I will send you some pics!
Jinxter
 :read: Just to let y'all know, I just brought home a 5.0 from (supposedly) an '86 'Stang with the AOD tranny to put in my '79 hatch.  I'll be watching this as your build progresses!  I need another daily driver before I can start mine, and I still need a rear, a TV cable for the tranny, plus other odds and ends.
I'm hoping it won't be too long!!!
Beat it to fit, paint it to match...
So is that rear sump situation causing any problems?
MANUEL72PINTO
Im building a 72 pinto drag car also. But one diffrence is that my pinto is built ford tough with chevy stuff.
gearhead440
Thanks, guys!  I also have the old swap manual.  Another good source of reference information is the MRE book detailing a V8 swap into a Ranger.  Similar concept and good info to ponder over a frosted tankard of ale.
bobscat
I ended up buying a set of Hedman's for my car, and they fit pretty decent.  However, they are not exactly the nicest out there.  I was kind of skeptical at first, but so far have not had any trouble with them, even with it occasionally seeing snow driving.  (Which I do NOT recommend for a v-8 Pinto, but sometimes you just gotta do what ya gotta do)  I have the pictures all ready for you 71pintoracer, just keep forgetting to bring my camera to work to download.   :hypno:
Hi gearhead, I bought my headers on e-bay, they are old but unused, not sure what brand they are. From what I have read there are two types, on mine the back two tubes go back and the front two go forward and under the crossmember. The other type have two tubes that go out the fender wells so there is some cutting required. I will post some pics when I get them back on. Summit sells the swap headers but I don't know which type. I think they are about $450.00 The "V8 swap manual" that I bought on e-bay says that if you make the front style mounts like I am doing that you can use regular V8 headers, but I'm not so sure about that. Looks really tight and just getting two tubes through there is snug. They give part #'s for two brands, not even sure if they are available or good numbers anymore, the book is really old, I can post the #s if you want. BTW, a friend called a company that makes swap kits for all kinds of stuff, they said they did not have a Pinto kit but were getting more and more calls for one, they are thinking of making one that would use regular 302 mounts instead of the hard to find and pricey MII mounts. I figure about the time I get everything fabbed and welded up and in place they will come out with one!!  :P
gearhead440
71pintoracer,
Great photos and progress!  What headers are you using for your swap?  I'm doing the same swap on my 80 Pinto and any input on headers, fitment, etc are always appreciated :).
Thanks!
Thanks bobscat. We set the engine in again last night, fits much better now. Got the headers on, we need to make a few minor adjustments and then it is going in for the last time! (I hope) Need to move the brake and fuel lines again, they are too close to the header. I ordered a short water pump from Ford Motorsport, it is 1-3/4" shorter. $140.00
bobscat
Cool!  Glad to see you are on your way to getting the motor in.  I took some pics of my car last night for you, but the home computer is so slow, I wanted to load them here at work.  As usual, I was in LaLa Land this morning, and forgot to bring my camera, so I will do that tomorrow.
We are going to do a little more trimming to the bottom left where someone (ah-hem) beat the crap out of it with a hammer, and there are two ribs on the top of the bell that are going to be notched. Should be plenty of room now.
 :'( I lied. I said I wouldn't cut this car up to do the swap, but after trial fitting the engine and trans half a dozen times, it had to be done. The top bolts of the bell were hitting and I still had about 2" of clearance between the rack and the front of the sump, and the headers would not bolt up. The engine needed to go back at least an inch. My brother the expert body man came down and looked it over and said "no problem". We drilled some holes in the junk '71 to see how far back the heater box was, a good 1 3/4". He measured and marked and got out the cut-off tool. I went upstairs to get a beer or so!! This is what it looks like cut out, we are going to make a recessed cover and weld it in. A little filler and paint and I think it will look a lot better than a hammered back firewall. Tomorrow we are going to set the engine in (again!), bolt up the headers and start making the motor mounts. When everything is where it needs to be the motor will come out one more time and the firewall will be fixed.
here are some pics of an '80 firewall and a '71 firewall, big difference between the two...so, as bad as I hate it.....
Smoothed up frame rails and relocated brake lines
YAAA! My son is off tonight so he loaded some pics for me. First..the chewed up Hyundai
bobscat
haha!!  awesome!  My friends and I have a couple of tricked out lawnmowers.  I will try to post a picture of the one labeled "The Beast"  Actually took it out on a state route and PASSED cars with it!  Are turf tires rated for 60+ mph??  haha Back on topic though, looks like you are making some headway.  I got your PM, I will try to answer some questions, and keep us updated with pics!!
Not much new to report..the MII pan is on and the engine is sitting in the car, still needs to go back more but the top right bellhousing bolt is hitting even with some firewall mods w/ a 3# sledge. My brother the expert body man is going to come down and have a look. At this point the water pump is about even with the radiator support, I would like to get it back two more inches, at the very least one. If any other V8 swap guys are reading could you post some info on where the front of your W/P pulley sits and what mods you did to the firewall?
Pintojunky, where do you stand with your swap? PM if you dont want to post here, but feel free to do so, everyone's info is welcome!!
On another note, the reason the Pinto has been getting limited attention is my Wife and I host a huge Memorial Day block party so we have been getting ready for that. Again this year we will be having riding lawnmower races. A bunch of us hot rod up old mowers and we have drag races, wheelstand compitition, and yes, they will yank the skinnies way up in the air!!  :fastcar: Then we have tug o' war, a figure 8 race and then we destroy them in a demo derby!  :accident: Funniest thing you ever saw!! My mower is a 12 HP Murry, it is painted up like my Pinto, has the engine raised up and back so it runs off of the big pulley and has a hand throttle on the governor so it can run wide open. It dang near flips over backwards when I dump the clutch! I will get my son to take some pics and help me get them on here-stay tuned!! :amazed:  :o  :drunk:
Scored a MII pan on e-bay, so I pulled the engine back out. The brake block needed to be moved, I unhooked the lines that go to the front & rear, left the M/C lines hooked up and moved it around to the fender apron. I rerouted the line for the rear so it runs with the fuel line, the fronts go back to the line lock which just needed to be moved down a little bit. You can get a union to hook two lines together, they are made just for brake lines so you don't need to run a whole new line, just add what you need. I've always been told never to use brass fittings with compression fittings to splice a brake line.
Here is the item # for the pan on e-bay- 330234394768. I dont know how to post the link
A little update, I got the Hyundai rewired and got the shop back together, did a little extra cleaning while I was at it. I was going to post a few pics of the chewed up Hyundai but my batteries are dead so I will try again later.
I've been doing some trial fitting and measuring on the Pinto, the headers need the extra 1" that a MII pan would give, another member gave me a link to a pan on e-bay that looks like the Milidon, it is $79.00 + shipping, I think I am going to order that one. (Thanks pintojunky!) He is doing a swap on his '73 so we will be trading ideas back and forth. He ordered the MII pan from Advance but it was indeed a regular 302 pan like we thought. He is using the MII mounts and said it lacked a good 1/4" with the pan sitting on the rack.
Geez!  What crappy luck!  At least the Pinto is safe!!!
Well I had planned on working on the Pinto this weekend but...when I came home from work Thursday and went into the shop, it looked like a tornado had landed in there! I was like  :wow:!! Tools and parts and books and oil and drain pans and antifreeze all over the floor, tool carts turned over, stuff strewn everywhere. I asked my wife " :wow: went on in the garage??!! We went down and then I noticed the walk-through door. At the bottom a big hole had been chewed half way through and a big oil spot in front of it. GROUNDHOG!!! Apparently Wed night when I pulled my little Hyundai commuter car in after working on the Church's van, a groundhog was under the hood, and he spent the entire day chewing up the wiring on the car and trying to escape. I could see his tracks were he spilled oil and tracked through it. (I had changed the oil and anti-freeze in the van and had just set the drain pans up and was going to pour it in the waste barrels the next evening). My wife and I looked around the garage for him and then she saw him sitting on the shelf behind the T.V. She said "Go get your gun and shoot him!!" Well, Mr. Groundhog didn't like that idea at all so he went up into the celing where he had chewed a hole where the cable wire comes through. I got my trusty old Ruger .22 and we spent the next three hours trying to get a shot at him! I have access panels so I took them out but there are rafters and wires and heat ducts in there so he had a lot of hiding places. Finally my wife took the air hose and shot air at him and he ran to the end of the house. I had to lay the rifle on a rafter and squeeze through the next one and reach around to squeeze the trigger. I whistled at him and when he raised up I shot him in the head. He flopped a few times and then stuck four feet in the air. So...now I have the task of putting my shop back together and rewiring the Hyundai. He chewed up the battery cables, headlight, fuel injector,alternator and ground wires as well as some vacuum and water hoses. The good news is the Pinto is up on jack stands and covered up so he didn't bother it at all.  :) I'm also thinking about putting in a little doggie, make that groundhoggie door!! :laugh:
Well, it seems I have been misinformed. ??? The MII pan and the standard 302 pan are different, even though if you go to the parts store they list the same part # for both cars. The MII is flat all the way to the sump and will give about 1" extra clearance. The other pans have a little drop about 3" before they get to the sump. I have the engine and trans sitting in the car, I have 1/4" clearance over the rack. I had to enlarge the trans mount slots about 1/8" on the outer sides and it popped right in place. The shifter sits 2" further forward than the 4 speed so I trimmed out the opening with tin snips, but the T5 shifter curves back then up and ends up in about the same place.
The MII pans are all but impossible to find, none on e-bay at this time. Summit sells a Milodon low profile pan for $215, the pick-up tube is another $42. Since I am on a limited budget (who isnt these days!) the engine may just have to sit like it is.
here are the mounts, they can be welded right back in if I ever decide to go back to a 4 cyl- check out the burnt paint from the headers!! ya think the nitrous causes the cyl temp to go up a little?  ;D
I think I got it now, here are the pics...
Well for some reason I can't get my pics to post, I will keep on trying. The stock frame mounts are out, after drilling the spot welds they came out smooth as butter. I really think you could get them out with a hammer and chisel if you had to. I drilled a 1/8" pilot hole to help line up the spot weld bit, it is flat on the cutting end as it is designed to just go thru the outermost metal. After that the mounts came out with ease.
I smoothed up the frame rails with a small grinder and put a thin coat of split second filler over them and sanded it all down. Turned out pretty good.
I hope to get the oil pan this weekend so I can set the engine in place and start mocking up the mounts.
Engine compatment looks messy, everything is pushed aside. Nitrous wiring and solinoids, line lock, cruise control, yes, cruise! Ford add-on no less! I will be taking out the stock mounts next, I started with my little muffler sized air chisel, that just hurt my ears. My brother ( the vetran body man) let me borrow his and he also gave me a special drill bit to drill out the spot welds and I bought hearing protection. These chisels make a LOT of noise!!
I haven't forgotten about you guys, just been busy! (Stupid yard work  :mad: )
Well the 5.0 is stripped down and waiting on parts, the oil pan can come from a bunch of cars or trucks from the 70's not just MII's. Advance has them for 59 bucks. On their web site is a link that lets you see what vehicles a part will fit, the pan brought up a whole page.    (edit: that last statement is not true. although the same pan is listed for the MII it will not fit. read on....)
The 2.0 engine and trans are out, some clean-up work needs to be done to the engine bay and some stuff will need to be moved I'm sure. You don't need to remove the hood, I have mine strapped to the garage door opener bracket, you can also stuff small blocks of wood under the hinges to hold it straight up.
I am ready and looking forward to it....Take your time and lots of pictures...Don't hesitate to ask oppinions...there are some very smart and experienced Pintdividuals on this site....Good Luck!!!!
  We can make it better...faster...and stronger...We have the technology.
Hello all, Well, I have started on the V8 swap in my '71. I know Pintony will be mad at me because he loves the little 2.0's! I do to Pintony, but mine is just too wild for the street. With 12.5:1 CR I have to run a 50/50 mix of racing fuel so it is costing $60.00 per fillup. I got the 302 HO and T5 Saturday, and the engine looks great! Very clean inside, all I am going  to do is replace the timing chain.
I will be posting pictures and text of the entire swap, so maybe it will help others who want to do this. I read on here that the swap manual on e-bay was crap, but no one would take the time to tell me why, so I went and spent the eight bucks for it. It is dated, the Ford part # 's are no longer available. But there is some useful info. I am going to make the mounts described in the book but with some modifications. This is going to be a somewhat lengthy project, time and money will dictate how long it takes. Stay tuned.....
