Date: 08/24/2018 02:50 pm
1980 Pinto taillights
Date: 12/26/2017 03:48 pm
1978 ford pinto carb
Date: 02/04/2018 06:09 pm
1973 Interior parts wanted
Date: 01/02/2017 11:02 pm
pinto floor mats??
Date: 01/11/2017 07:27 am
Date: 11/05/2020 06:32 pm
Many Parts Listed Below
Date: 04/20/2018 11:15 am
Date: 02/21/2017 06:29 am
Offenhauser 6114 dp
Date: 09/12/2017 10:26 pm
  • Online today: 586
  • Guests: 120
  • Total: 120
71 V8 swap-let the fun begin!!
Started by 71pintoracer, April 16, 2008, 09:25:18 PM
reading this thread might help you in that department
lilpinto
hi im new to the pinto culture....really i have a bobcat...im not sure of the year.  id really like to do a 302 swap but im not sure where to start.  any little tips tricks and pointers will help.  THANKS lilpinto
77' bobcat gettin 302
Thanks 71HRP, you touched on evrything just as I would have said it! Like you said, it's no corner carver but quite honestly, mine drives very good. It's lowered 2" so that helps, and I have 195/50/15's on the front,205/50/15's on the rear, I had my rims custom made with most of the offset to the outside for a wider stance.
The thing of it is, it's a HOT ROD! It's a loud, noisy, powerful, handful of fun!! It's not a family sedan with P/S, P/B, A/C, ect. ect. (Although it does have power windows and cruise control!) When you drive it, you have to drive it. When you nail it, you have to hang on! I'm very pleased with the way it drives and handles, and I love the way it gets sideways in 2nd & 3rd gears!
Quote from: popbumper on September 01, 2009, 09:24:10 AM
Very nice, I appreciate the feedback. I >DO< have a front sway bar, so that's probably a good thing. I just put in new springs, but they are "stock replacement", so I probably need to get bigger ones. If I was to go this route, I'd also opt for beefier brakes and do a 5-lug conversion.
Plenty of room in a wagon to move the battery! Aluminum heads - no problem. I have 13" rally wheels, I would definitely go with fatter tires all around.
I guess your "throttle" comment says it all  :lol:
Thanks!
Chris I do have a set of front springs that were A/C springs on my 75 and they had my front end up tight without the weight of the A/C whic was stripped before i got it. Also I have the fron bumper off.  If you need them they are yours for what it cost to ship.
let me know.
jwise12345
You know, it's feedback like that that really makes me more confident in doing a V8 swap. It's nice to know that when I run into a problem, theres 50 people on here ready to help becuase they've already solved it.
Thanks!
71hotrodpinto
I can say this about the current handling on my car.
It has no sway bar at all on the front.( Although i DO have a 1" that WILL be going on it after i MOVE! Yahh hoo! sorry LOL)
V8 Mustang II springs cut about 1.5 coils. If you choose these Cut them at least 1" higher than you think you want because they will sag after about a year.
Koni shocks all way round. Very expensive now, but get some KYB's "Gas a just" instead
It rides very nice and handles very well considering the extra weight and no sway bars (yet). No its not going to carve any corners but thats not why i built it.
Move the battery to the back and run 2 wires to the battery. Red and Black and ground to the body front and back as well.
Iron heads. You can use Aluminum heads which will take about 50+LBS off the front.
Run some decent tires up front at least 195's to 205's wide . Yea i loove the look of "Big n littles" but lets face it unless your building a drag only car, skinnys are very dangerous on the street with a front heavy car.
Bottom line , when you lay into the throttle and leave 100' stripes you wont care how fast it goes around corners!!
B303,1.7 Rockers,beehives
'68 port/polish heads
Coated Must II headers
Edelbrock Airgap
Holley570,Msd dist,CraneHI6
Mil
Quote from: 71pintoracer on August 30, 2009, 07:47:49 PM
8" w/3:55
Hey Pintoracer:
  I trust your judgement, knowing your setup. I have been very hesitant to do a V8 swap ONLY because of the added weight on my front end ('76 wagon). What is your overall impression of the weight impact on your front end? Is the car still manageable? Does it make a huge difference? Is the cornering compromised greatly? The way you talk about your car says you don't mind at all, but I'd like to know what I am "up against" if swapping in a V8 - from a PERFORMANCE/WEIGHT issue, not the task itself. Thanks!
looks like someone is having a BIG birthday this week.  ;D  hey age is just a way of keeping score.
my score is just behind yours. Hope you get some nice goodies. And in case im not here wed.  :happy_bday:
jwise12345
hi there. quick question, what rearend and gears do u have in your car. just curious. ??? :)
Thanks for the kind words! :) Glad to see that I had a small part in saving another Pinto! The '78 is a great car to do a V8 swap. That is my second favorite body style, I also have a '77 cruising wagon that I hope to be working on this winter.
David's car (the red one) is very nice and he did a fantastic job on the swap.
Feel free to ask for any advise you need, either by a post or PM. Since your'e a derby driver, I feel sure you are good at fabrication and "makin stuff work"!!  :fastcar:
cjlangellier
Your 71 looks great.  I have been a member on this site for a few years, but never really came here much until about a month ago.  Your build has inspired me to transform my 78 trunk model into a little sleeper with a 302.  You most likely will be glad to know that your project as well as the other red v8 project thread on here have single handedly saved my pinto from a demolition derby death.  Just wanted to let you know how good your ride looks and let you know that I will most likely be contacting you for advice later this winter.
Thanks jwise, glad to see people are still reading this. The V8 swap is very popular, just not as easy as drop it in, bolt it up and drive away! The '74 is a better choice because of the larger engine bay. Lots of good info on here and lots of good folks to lend a hand with any questions.  ;D
jwise12345
thats a hell of a sweet lookin ride. i'm currently starting my transformation of my 74" hatchback into a Bitchin Cruiser with a 302 and a 5 speed. Your story was a lot of fun to read and it was nice to be able to look at a completed one to see just what im in for. looking forward to new topics from you.
Hey Mark, thanks for the kind words! I'm really enjoyong the V8, even with a basicly stock engine its got gobs of power. I just finished the sub frame connectors, see my post in this section. (Weld in sub frame connectors, how to) Good luck with your build, PM if you have any questions, I'll try to help!  ;D BTW, as far as moving the rack down, you have to cut the crossmember and box it in, (for the steering shaft) lengthen the shaft and modify the spindles to keep the geometry right. I have 1/2" clearance and my scoop sits perfectly out of the hood, so I'm happy with mine. However if you're trying to get it to fit under a stock hood with no scoop (sneaky sneaky  ::)) most likely it will need to be dropped.
pintoguy77
Hey 71pintoracer,i cant wait to see pics of the frame connectors.Im building a 77 runabout with a 289 4 bbl and im gonna need detailed info on how to make these connectors.Damn your column is right interesting,i read it all and enjoyed it very much.I pictured myself in your shoes cruising down the road in the finished product,geez,cant wait till i can turn my last bolt.Some people actually move thier steering racks down an inch or so but cant figure out how they do it with the steering coupling almost down against the cross member.Oh well,thanks for all the pics and stuff and have a great day.....Mark,Eastern Canada
I am going to start a new topic for the sub-frame connector install. There seems to be some interest on the subject so I thought it might be a good idea to make it a separate topic. I did a search and got some good ideas on how others did theirs. Had to take a break on the Pinto and work on my daughters VW Beetle to get it ready to be painted. I HATE body work!!  :cheesy_p: All you get done is sand, sand, sand! Hope to spray it one day this week, then its back to the Pinto!  ;D  So I guess this topic is done, thanks to all for the comments and for taking a look at my V8 swap!
Wow! It's been two months since I posted anything here! All I have been doing with the Pinto is driving, driving, driving!! Well, it looks like it is finally cold for good here in central Va. so it is time to park the baby and get some more work done to her. I had two 5' pieces of 1/8" channel iron made for the subframe connectors, I'm going to get started on pulling the inerior out and getting those fabbed up and welded in.  I also have a driveshaft hoop that needs to go in. Pics will be coming soon... :smile:
CHEAPRACER
Quote from: 71pintoracer on October 03, 2008, 09:15:53 PM
12:08 @133MPH.
Wow, that's an high trap speed for that ET, better continue working on that cage.
Wow, over a month since I posted anything, I guess that means I'm done!!  ;D  Well not quite, I still need to fab up the subframe connectors and most likely I will put in a cage of some sort. I'm just having too much fun driving it right now, I don't want it sitting until this winter, so I am not planning on taking it to the track this year. I don't want to take a chance on twisting the body, I have 13" X10" wide M&H Racemaster slicks and if they hook good with the torque this engine has well it might just pop the doors open!!
I did make another run on the G-meter with the street tires, this time I took off in second gear, easing down on the throttle and keeping as little wheelspin as possible but it still spun all the way through 2nd. This time it ran 12:08 @133MPH. This car is sooo much fun!! Hey rice burners!  :2fast4u:
It's at the Harrisonburg First Church of the Nazarene at the corner of Port Republic Road and Boyers Road.  They have a HUGE parking lot and you can't miss it.  The official time is 6:00 - 9:00 p.m. but lots of folks get there earlier.  My entire family has hair appointments scheduled at 4:30 so I don't imagine we'll get there much before 6:00.  They will hold it rain or shine (I went one year and got soaked) but I won't be there if it's raining!  Both me and my car are getting too old for that kind of nonesense!  Hope to see you there!
Hey Dwayne, the show is at Fisher Auto Parts in Staunton, hosted by Churchville Fire Dept. Where is the cruise in being held in H'burg? I'll try to make it.
Way to go, Jimmy!  It turned out every bit as fantastic as I knew it would!  What show are you attending next Sunday?  I have to work next weekend but, weather permitting, we're planning on taking one of our old Lincolns to a cruise-in in Harrisonburg Friday night (9/5/08).  We've participated in this cruise-in for several years and I have yet to see a Pinto there... you should come on down and give those folks something to look at!
And here is the top, time to get the rest washed and waxed, we're off to a car show next Sunday!!
Here are the pics, the hood really turned out good, looks like it was made that way.
The close up shows the texture that was sprayed underneath.
Thanks High_Horse, I'm just having fun cruising period! This thing is a blast to drive!
Work is progressing on the hood, had a few stress cracks to deal with. We stiffened it up by using fiberglass mat underneath and got that all smoothed up and seam sealed. Then we used a product similar to spray on bed liner but in white. Really turned out good. Looks like a fiberglass hood and you can't tell that it was cut out and had something else molded in. Then we redid the top and got it all smoothed out and primed and block sanded. The blue base coat is on, Monday we will put the hood back on, lay out the design and get the white and yellow sprayed, clear it and bake it. I'll post pics soon.
71PintoRacer,
        Very nice car!!!!!!! Very nice car!!!!!!!!!!!!! Definitly a potent v8 Pinto Warrior. I am looking forward to cruising with you during the big Pinto invation......................Badass!!!!!!
Regardless who did the actual work, folks, the hood looks great.  I saw it last Monday evening and it is nothing short of fantastic!  Can't wait to see the final result once it's painted.
