1971 2 lt Cam
Date: 10/10/2020 06:27 pm
TWM Intake
Date: 08/15/2018 08:20 pm
Pinto Parts for sale
Date: 06/19/2017 02:01 pm
Date: 06/18/2018 03:47 pm
Date: 09/10/2018 10:41 pm
Date: 08/09/2018 07:49 am
Date: 10/05/2017 02:26 pm
1980 cruising wagon ralley
Date: 07/12/2019 01:41 pm
1978 RUNABOUT
Date: 04/01/2017 03:18 pm
  • Online today: 586
  • Guests: 300
  • Total: 300
Electric Fan
Started by Fair 73, April 16, 2008, 03:44:18 PM
Fair 73
 Hey guys I wanna thank all of you for the input. It looks like I will try and make a shroud for it my only other question is do you think an aluminum radiator would help cool better than my copper crossflow.
Thanks again
Luke
CrazyHorse,
     Your not so Crazy.....I used plastic drum material for the dam on my 85 chevy wagon and it was a breeze....easily formed and strong as heck....and you are right about the fan shroud...the farther back the fan is from the radiator the more suction force is attained due to volumetrics...this would draw  more evenly on the radiator. The stock blades although designed to draw, do generate alot of turbulence at close quarters. I will say though that electric fans are designed for close quarters as are aftermarket flex fans.
Blue plastic barrels make good fan shrouds. Plenty of material to work with, and easy to cut & form.
Placing the fan closer to the rad will help, but shrouding it as it sits will likely be more efficient, and easier on the water pump. I've seen V6 Camaros with 2ft deep shrouds.
I agree that the mechanical fan is much better. Some sort of shrouding should be employed for maximum effect. Also, an air dam would help under the bumper to create a void so that the hot air in the engine compartment is pulled out under the car.
1975 pinto
Quote from: 77turbopinto on April 16, 2008, 07:36:57 PM
I think he posted that he can't run it in front, nor can he run the two fan set-up.
A stock fan on the waterpump will pull FAR more air than almost any electric of the same size. Pullers move more air than pushers of the same size.
IMHO: You are better off with the mechanical fan. Get a bigger spacer to move the fan closer to the radiator or get a bigger or higher number blade fan (as long as your belts will pull it). If you need more air, install a fan shrowd.
Bill your absolutly correct, I mis-read the post.
6 miles south of Dayton, Oh
Quote from: 1975 pinto on April 16, 2008, 07:22:17 PM
I dont see why you couldn't mount it on the non-engine side. Some 427 Cobra's  run the same type of setup. You would have to buy a pusher fan, but it should work. It would flow much more air than the regular fan, and if you run it on the outside could you run a dual fan?
1975 pinto
Fair 73
 Hello
  I have looked through old posts with only a little luck on this subject so I hope someone can help me.
I got a 73 Pinto that we put a 302 in quite a few years ago. Right now it just has a regular 16 in fan on the motor with no shroud and about a 2in gap between fan and radiator. I am useing a cross flow radiator with a core surface of 22.25 x 15.5 and 2in thick. I was wondering if I were to take my fan off and go with some type of electric fan if it would cool much better. I wonder how much air the fan on the motor would flow through the rad as compared to electric?   I would only have enough room behind the radiator because theres no room behind the grill. I am having trouble finding electric fans thin enough to fit between the rad and pulley only about 2.5 in at most. The core surface is too narrow for most duel fan set ups.
I guess what I am wondering is if I mounted a 15 in electric fan on the inside radiator would it pull enough air through it to cool it better? (my concern is that there would be about 7 in of core on each side not having air pulled through it)
Any help appreciated.
