Date: 02/14/2018 01:34 am
1978 hatch back
Date: 11/29/2019 03:18 pm
1979 PINTO PARTS--FREE
Date: 09/13/2022 02:05 pm
Date: 03/17/2019 10:15 pm
Date: 06/12/2018 08:18 pm
Pinto drive train
Date: 06/29/2018 08:32 am
71-73 Pinto Parts
Date: 06/06/2019 10:47 am
Date: 01/04/2017 04:07 am
SVO SWAP
Date: 03/15/2018 03:12 am
  • Online today: 2,399
  • Guests: 1464
  • Total: 1464
1977 Pinto- project in the works
Started by r4pinto, April 07, 2008, 07:54:57 PM
Thanks guys. It is frustrating bigtime but nothing that can be done about that. All I will do in this case is drive it & enjoy it while I still can & once I find a replacement I will pull everything from this car & put it in the new one. The only thing that will be left is the worn out parts & rust. I would like my next Pinto to be a wagon but I won't rule anything out. The only thing I am looking for is a Pinto with a good body & floor 74-80. Then I can make it looking similar to what Harold II is.
I feel your pain. I ran into ther exact same problem with my '78 sedan. The rust was everywhere once the fenders came off & it's not worth saving. I need most of the parts off the car anyhow including the clean floorpans so it won't die for nothing. It will live on having provided everything needed to finish my '80 & '73 both.
Matt,
It is a sad day, indeed... but best of luck in your search for Harold III.
Dwayne :)
Alpine615
Aww Matt, that is sad news indeed. But the rust you describe sounds so thoroughly complete that it most likely is the best move. Best of luck in finding a suitable replacement!
1980 Runabout
I am afraid the project is at an end.. The car is just too rusty underneath to save. The car has severe rust to the floor, wheel wells, right leaf spring shock mount, firewall rust.. The car is too far gone for me to continue trying to fix this car. With that being said I won't be able to save the car. There comes a time when you realize that some things cannot be saved and this car is definitely one of them. I will be looking for a replacement car for Harold II and when I find one I will swap out all the usable parts before junking the shell.
Sad, sad day for me & the car. I hate to end a project when it is not finished but in this case I don't have a choice.
Thanks Dwayne! I wanted a pic with the similar stance of the old one & got around to changing it. There will be no getting pulled over by WV cops this year. The headlights work & the car is quiet lol.
I do need to go to NAPA in the morning to get me another headlight adjuster screw. One of the ones I bought on ebay before decided to break when I was trying to adjust the light, so it's now pointing to the center, like it did before. Oh well, no harm no foul. I am also going to change the oil & go to Maaco to get the parts. If they are not done this time then I will have their heads on a pole. If I have to drive the car with no front end to Carlisle I will but I will be very very pissed if I do.
Hey Matt!
I like the updated picture of Harold II - much more indicative of what she looks like now!  Have a great time in Carlisle!
Dwayne :)
The exhaust is fixed!!!! It took two adapters & a couple nuts & bolts but the exhaust is finally up in place for the first time in a long long while. No dragging or anything! Carlisle here I come!
Well I removed the old speedometer cable & neutral safety switch & both were shot. The plastic center post on the neutral safety switch was gone altogether, which let the sp& apparently rusted in the housing that when I spun the gear it was to stiff & hard to rotate that I think this was causing the issue with the inaccurate speedometer reading. Having an issue with getting the plug on the neutral safety switch. Just a very tight area so it's being a little tough to plug it in. Now I am also still waiting for the parts to be finished by Maaco. For whatever reason they are having issues with the paint.It keeps getting fisheyes & they are not sure why. If the parts are not done my Tuesday heads will roll since I am going to Carlisle on Thursday.
Now for an update... I have taken the headlight buckets & bumper filler off the car & took them in to Maaco to be reshot. When  the car was painted last year the paint stuck pretty good but it started to flake off. From what I could tell a flexible additive wasn't used. No harm, no foul. better to take care of it now.
Aside from that I went to the junkyard today & was able to get the power brake set up from the 78 Mustang II. I got everything I needed, including master cylinder, brake booster, & brake pedal. I also got the proportioning valve & found out that won't need changed. Kinda irritating when you get the part & find out it's the same exact part number as the one on the car. Oh well, at least I have a spare to throw in the parts bin. I also got the neutral safety switch, alternator bracket for the power steering set up & vbelts. They were almost new & have no cracking at all & for only 99 cents each!
LOL that sounds cool. I try to go to that every year, although I forgot about it last year until two days after the fact.
bbobcat75
thats funnt my wife is from bexley!!
miss the roads up there but not the weather!!
well if im up in for thanksgiving will be at ford swap meet! might meet you then
eric
1975 mercury bobcat 2.8 auto
I'm from the Columbus area. Been living in Reynoldsburg for the past 18 years.
bbobcat75
matt
off topic but what part of ohio are you in??
im orginally from cleveland area.
No front end.
Went to the junkyard to get the parts from the Mustang II but had nothing but problems. First problem was getting in the car. Apparently the damage on the driver side was so bad it jammed the door shut. Once I got in it I found I didn't have the right sockets or wrenches to remove anything. Apparently the car has standard fasteners & no metric fasteners. Wierd how my 77 Pinto had a mixture & the 78 Mustang II doesn't seem to. Gonna go back Saturday to go after the parts.
I did go ahead & remove the front panels on the car. Last year when I had the car repainted it looked good but a few months later the headlight buckets were flaking badly. I went ahead & removed them, as well as the bumper filler & will be taking them to Maaco to have them redone. Can't have the car looking like crap for Carlisle. While the buckets are off I'm gonna go ahead & remove the left front fender so I can take care of the insane door gap at the back. Never had it right so now it will be right.
That's a good idea Brian. If anything I will get the parts now & install them afterwards. Not gonna miss Carlisle for nothing!
Quote from: r4pinto on May 14, 2012, 11:49:54 AM
get the power brake booster & master cylinder. By the end of the week this car will have power brakes!
you will need the brake pedal and mounting too... I'm not sure what all is involved in this conversion but you may want to wait until after Carlisle unless you are aware and have everything ready for the swap. Hate to see you miss Carlisle because you got stuck in the middle of a project and not able to complete in time.
2 1/2 weeks to Carlisle & now I'm feeling it!!! Haven't had the energy or motivation to work on the car so I am forced to cram a lot of work in a short time. Oh well, I can do it.
Anyways, I recently went to the junkyard for a part for my friends car when I found a Mustang II. I got the silver wiper arms & air cleaner tube at the time & will be going back Wednesday to get the power brake booster & master cylinder. By the end of the week this car will have power brakes! Next step is power steering. & floors. I have some of the parts but not all of them. Either way this car is a big pain in the butt. I have a lot of welding to do & I dunno how to do that. I need floors so very bad & am going to figure out what I need to do it.
Quote from: blupinto on March 13, 2012, 06:34:50 PM
Here's hoping you're driving her today!  :D
It didn't happen. It kept raining & with the funeral showing I was going to there just wasn't any time. I ws disappointed since I planned on driving her in the funeral, but what can you do.
Well, since it was a warm day I went ahead & dropped the steering column to find the culprit of the short. Two wires were crushed by the steering column & eventually wore through & shorted each other out. When the turn signal switch went bad I got one that had a longer harness & just crammed the crap out of it so I could make it work. It did for a while but apparently I pinched a couple wires when I bolted up the column & the rest is history. I had kept the old one in case I ever got motivated to shorten the harness & well, I sorta had to in order to keep from having another short. I got the turn signal harness all shortened up to match the original equipment harness, cut out the bad wires & soldered in new ones & put everything back in place. The final test was the hazzard flashers & brake lights. No more blown fuses!
Next in line is to try to fix the exhaust so I can drive the car tomorrow. The Grand Prix doesn't get the gas mileage the Pinto does so I wanna get it all fixed so I can drive the car. We'll see what happens.
Haven't really done much to the car since September but recently I was having to drive the car after my 08 Grand Prix was in the shop for some warranty tranny work. I was driving the car for a bit when the brake light fuse blew. I think it's a shorting wire in the steering column so once it warms up I'm gonna give it a whirl to fix it. The car is loud & fires right up but doesn't have brakes. Once it warms up I'm gonna take care of the suspension, exhaust & electrical issues. Such a good car. 32 years old & keeps on trucking.
Got the driver side leaf spring installed today. Dad & I were working hard on getting that taken care of since the old one was busted up really bad. The driver side rear tire was not centered in the wheel well & it was suspected to be due to a rear leaf spring installed backwards. Well, that was not the case. The spring was so broken that while it was not moving freely the axle had no way to be centered when installed. Got the rear leaf spring installed on the driver side & it took care of the problem. Now I just need to replace the passenger side spring & replace both shocks. Then the car will drive better. Soon it will be my daily driver as the Malibu Maxx fuel pump issue is back with a vengence. Before long she prolly won't be starting or running so I gotta get the Pinto road worthy.
Well I got the starter button hooked up so I no longer need to pop the hood to start the car. I ran two wires from under the hood into the interior & hooked them up to the starter solenoid. I did have an accident with the starter solenoid & had to replace it with my backup unit. I was using a nut on the S terminal stud but it was the wrong thread. Instead of cross threading the nut or stud it cracked the solenoid. Oh well, it will work for now. I am going to mount up the switch below the radio using one of the screws for the radio bezel & a mounting bracket fabricated out of some scrap metal.
Is it necessarily the right way to fix the problem? No... that would be replacing the neutral safety switch, but it will work for now.
The car has been sitting on the street for about 2 weeks since I couldn't find the keys to her. I found them a couple days ago & moved the car in front of my house, just to pi$$ off my neighbor's oldest son. My dad decided to start parking in front of the house after the neighbor's son parked in front of the house on trashday, causing us to have to put the trash outside the rental house next door. I got the keys, jumpered the solenoid & moved the car. This weekend I plan on getting a toggle switch & some wire to run in the car so I don't have to pop the hood to get the car to start. This is just a temporary measure, but will work until I get to the junkyard to get a neutral safety switch for her. I'm also gonna get the rear leaf springs & shocks on the car, so she will be ready for the Ohio Pinto meet in September.
Thanks Brian,
The next step is to tackle the suspension. A couple years ago I bought a couple lower control arms off ebay but never installed them. I have gone ahead & installed the new ball joints on the lower control arms & am getting ready to install the bushings in them as well. While I have the lowers off I will be installing new coil springs, upper ball joints & control arm bushings, as well as replacing the strut rod bushings. Of course new shocks going on the car. I'm also going to redo the rear suspension. Rear leaf springs & shocks are coming to the back.
I did go ahead & install one shock last week & noticed the old one still held pressure. I was shocked, but they were showing their age. It had pressure but not as much as the new ones I bought off ebay.
Matt, you car lived up to expectations and looks great, hats off to a job well done.
Quote from: Scott Hamilton on June 12, 2011, 09:34:39 PM
Matt,
After seeing her in person at Carlisle, she's a looker!
Good seeing you again,
Scott
Thanks Scott, Makes it all worthwhile to hear the compliments.
It was great seeing you again too.
Scott Hamilton
Matt,
Scott
