2.3 carb intake
Date: 07/15/2020 09:25 pm
Clutch Fork
Date: 03/31/2018 09:12 pm
Date: 09/15/2019 12:38 pm
Date: 04/12/2017 08:15 am
cam pulley
Date: 05/30/2018 04:56 pm
WTB Cruising Wagon
Date: 12/07/2016 05:35 pm
Date: 09/12/2018 12:33 pm
Date: 09/01/2017 11:58 am
WTB Cruising Wagon
  • Online today: 1,292
  • Guests: 668
  • Total: 668
Electric Fuel Pump
Started by mdspeedster, April 01, 2008, 10:59:45 PM
mdspeedster
turbopinto72,
I sent you an email.  Thanks.
CHEAPRACER
Quote from: mdspeedster on April 03, 2008, 03:28:49 PM
Does anyone know of a source for a block-off plate to replace the old mechanical fuel pump?
They also come factory installed on the fuel injected engines.
Quote from: turbopinto72 on April 04, 2008, 10:37:58 PM
I can make you one no problem, just let me know.
Yes! And anything turbopinto72 makes is top notch!!!!
turbopinto72 makes some of the Coolest Pinto parts out there!!!!
mdspeedster
Are you selling these or, if not, where do you buy the billet aluminum?
 I make them out of billit aluminum.
mdspeedster
pintoches
I think that most carbs on stock eng. only need 5-7psi   I don't know about GPH!
I think you should look at this post about cut off switchs
http://www.fordpinto.com/smf/index.php/topic,2174.0.html
Ches Lathim
72 Pinto Wagon
78 F150 4x4
87 ford F150
mdspeedster
I have a 1923 Track T running a 1978 2.3L with a 2-barrel carb.  There isn't enough clearance behind the side hood panel to clear the fuel pump hose.  I want to replace the stock mechanical pump with an electric pump but don't know what to use.  What PSI and GPH do I need for this setup?  Any suggestions on sources or specific pumps?  Also, where can I get a block-off plate to replace the stock pump?
Thanks!
