Date: 06/18/2018 03:47 pm
MISC PINTO PARTS
Date: 08/27/2017 10:23 am
Date: 03/25/2019 09:02 pm
Mustang II V8 swap parts
Date: 03/26/2017 02:25 pm
1979 Runabout Rear Panel
Date: 01/04/2020 02:03 pm
1971-73 2.0 motor moiunts
Date: 05/17/2024 09:18 pm
'79 Ford Pinto, Green,
Date: 10/29/2019 11:50 am
74 Pinto wagon armrests
Date: 01/18/2017 07:04 pm
Date: 01/23/2023 02:22 pm
  • Online today: 925
braking stalls out car
Started by vegetableman, March 29, 2008, 11:34:50 AM
Quote from: Fred Morgan on March 30, 2008, 12:57:44 PM
.... Fastest way to find leaks have eng. running take wd-40 spray all intake conections.....
I would use somemthing NON-FLAMMABLE. Some of that non-flammabe 'low VOC' brake clean that won't clean anything is what I use.
Possible vaccum leak, small leak will give you hi idle speed. So like the other guy said look for cracked rubber caps and hoses. Fastest way to find leaks have eng. running take wd-40 spray all intake conections, dont forget brake boost if you have and also intake man. to head, when eng. r.p.m. changes thiers youre leak. :)
Starliner
Could be a low float bowl level too!
1973 Pinto 1600 - Sold!
1979 Pinto 2300 - Sold!
apintonut
i would 2nd a vacuum leak. most 2.3 leak at where the auto kick down hooks up. on the back of the intake manifold there is a vacuum tree that has rubber plugs on it they go bad
74 hatch soon to be turbo 2.3
73 sedan soon to be painted
stiletto parts(4 sale)
79 pinto wagon & beentoad
I bet its a car with power brakes.
Sounds like you have a vacuum leak.
vegetableman
havent really tried anything yet but i noticed that the carburetor is making a whistling noise i never noticed is that normal?
Youre right I forgot they dont use points, all my engines thru the 90s have point dist. so you can see why I whent their.  :)
I thought a 79 didn't use a points distributor, though. A regular tune up or a distributor rebuilt might be in order. Or try Pintony's centrifugal flyweight fix. It's somewhere on here.
If you can throtle up at good speed then fuel filter is not cloged. 1st easy most common is engine normal op. temp. adjust idle mixture, small screw near base of carb. go for highest idle r.p.m. then back out 1/4 to 1/2 turn if you have good ears otherwise use tach.. Then go for point gap dwell prefer over feeler ga., gap plugs, plug wires to old and you know they are not wires, listen for snap sound around wires, open hood at night look for blue arc jumping, check dist. cap for cracks. And if that doesnt work then you have serious crap going on, such as low comp.. Any way check that 1st. then get back with me and I will tell you how to pump air down cylinders. From the aircraft guy. Have fun  :lol:      ???
vegetableman
hey ive got a 79 and i just patched up a leaky gas tank and the car was running fine for a week. this morning it started stalling out everytime i braked and stopped the car. it feels like the car isnt getting enough gas or maybe its carburetor issues? any suggestions?
