Rally spoiler wanted
Date: 05/04/2017 01:32 pm
SOME PARTS FOR SALE
Date: 01/11/2017 10:45 am
parts needed
Date: 02/20/2017 07:58 am
1980 Ford AM radio
Date: 12/22/2019 11:57 am
Need Interior Panels
Date: 07/09/2018 04:59 pm
99' 2.5l lima cylinder head
Date: 01/13/2017 01:56 am
windshield
Date: 04/14/2018 08:53 pm
Misc. Pinto parts
Date: 11/09/2019 04:25 pm
Date: 04/25/2017 12:17 pm
  • Online today: 1,137
  • Guests: 790
  • Total: 790
79 Gas tank...where to buy? -OR- best way to repair?
Started by Starliner, March 29, 2008, 03:43:25 AM
Hi Starliner, I recieved youre mail. I tried both e-mail and I can't get through to you. Give me some time, I will pull tank to get visual on it + dimensions + weight.I will get back soon as I can. Busy mailing out pinto parts all morning. Sounds cold hear it's double, because I live in closes as youre going to get to hell. Thanks Fred.  :)
Starliner
Hello Fred,
I sent you an email.   Is $125.00 enough to cover your time & shipping.
Let me know.   I will have wifey send a check.
This will help me a lot.   Wifey feels grounded without her Pinto.
About the weather...  I am in Xiamen, China right now on business.  The weather is in the70s  :lol:
Wifey in Michigan says it's raining and 40s-50s today.   Then it will turn cooler again.
1973 Pinto 1600 - Sold!
1979 Pinto 2300 - Sold!
Starliner how is weather there? I wanted $50.00 for tank + shippig and i'll throw in sending unit + staps + bolts if needed. Tank is still in car, should be good it's an arizona tank, it would be comming from 85344. Tried to e-mail you I don't think it worked. Get back to me here or spot7768@netzero.net or 760-665-2316.  :accident: hate that when that happens.  :)
Starliner
Do you want to sell the 78 tank?  Send email to:   p1800es72    at    yahoo"dot"com
Thanks!
Hey dont build tank to much labor involved. I have a 78 tank arizona style no rust. But check out my post on youre pintos under fuel tank. Also I used an elec. fuel pmp. with `G`switch and it worked in sandy eggo ca..  :)
302Pinto
I have the same problem with my tank. I asked around several different junk yards for another one but of course there weren't any. When I asked some welding shops to make me one they said it could cost somewhere around $600-$700. So my solution was to buy a 14 gauge 4'x8' steel sheet from NAPA which cost about $75 and have a friend help me with bending and welding it. It should work even better considering the metal is significantly stronger than stock.
Starliner
Wifey's 79 has a gas leak along the straps on the bottom..  Yeah, rust through!   :look:
Upon further inspection I found the bottom of the tank has been fixed multiple times with "gas tank repair" sealing kits.
The holes will keep appearing if I follow the same path.  Also I need to change the fuel filter too often.
I can't find a new gas tank, is there a source?
If I can't find one, what method worked best fo you to repair your existing tank.   (and get the rust out & seal it)
