Date: 06/05/2018 09:13 pm
Date: 02/05/2020 11:06 am
Wanted 1973 Ford right fender
Date: 06/03/2017 08:50 pm
Date: 02/03/2018 11:28 am
1972 Pinto SCCA BS race car
Date: 10/23/2018 04:01 pm
Date: 06/19/2018 03:58 pm
1973 Pangra
Date: 01/06/2015 02:19 pm
75 wagon need parts
Date: 05/28/2020 05:19 pm
Date: 05/18/2020 10:22 pm
  • Online today: 548
  • Guests: 479
  • Total: 479
battery relocation
Started by woodie, March 22, 2008, 08:28:26 PM
woodie
yes it is sealed and will have a vent. sorry about the headache map  thanks to all woodie
watch this
V8pinto_306_n2o
Quote from: map351 on March 24, 2008, 03:31:14 PM
#1 It's a starter RELAY.
#2 It don't PUSH anything, It closes a circuit, current passes through the  RELAY when triggered Via the IGN switch to the started SOLENOID that engages the drive gear in the flywheel..
#3 It doesn't make any difference where the RELAY is LOCATED..
Now i have a Headache!
Absolutely - yes it's a RELAY
Back in electronics school they teach you to think of electricity like water so my "push" nomenclature was related to my schooling.
Yes - the relay can be at the front or rear - this is exactly the point I was trying to make.  Either way you end up with a hot wire traveling the length of the car.  It's just that it's either a 00ga or something lighter (I have two 10ga's ganged together).
Of course all of this assumes you are trying to be NHRA legal with a master cutoff etc.  If you're not then there are more options.  Not for me though.
earthquake
Quote from: Pintony on March 24, 2008, 10:31:06 PM
OK, yea! a fused cable is OK but I'm curious could you use a fuse with a starting cable???
I too have the BIG fuse on my Alpine system and YES I have to carry spares.
I recently bought a circuit breaker for my system to eliminate the fuse. but I still have the BIG fuse near the amps for extra protection
My Battery cable runs from the battery forward to the solenoid so far no problems.The starter actually pulls less amps than the stereo.
map351
73 2.3Turbo Pinto
6S1941 / 289 Slab Side
Pinto FiberGlass
Quote from: map351 on March 24, 2008, 11:36:08 PM
Since 1967 95% of my cars had a rear mounted batteries some had 2. Maybe I'm doing something wrong none of my cars burnt to the ground due to a shorted positive cable.
I use 00 welding cable to the STARTER RELAY! Use common sense, keep the cable out of way on the out side of the frame rail.
I don't see what the big deal is on this issue....
Hey Mike,
I've never done it myself??
Iduno I'm just going by logic.....
If you say it is OK then that is fine by me...
map351
73 2.3Turbo Pinto
Pinto FiberGlass
It is actually safer to run the selenoid back by the battery and have the smaller wires (starter and ignition) hot back to there. I chose to run the big wire hot to the rear ...but...I ran it outside the car in conduit. If that big wire shorts somewhere there is going to be some serious heat  till the batts blow or the wire goes. And I prefer it to be outside the car. By running a couple of number tens....fused...One would have them circuits under control and not have a big heat hazard inside the car. I have planned to install one of those power disconnects but have yet to do so. I need to get that on my list.
Quote from: earthquake on March 24, 2008, 10:17:21 PM
The hot cable is no big deal.I ran an 0 gauge audio power cable and installed a 500 amp fuse 6 in off the battery.This does require that you carry a spare fuse as you are not likely to find one out on the road should anything happen.
I reciently bought a circuit breaker for my system to eliminate the fuse. but I still have the BIG fuse near the amps for extra protection
earthquake
Hello Map351,
R U saying it is just as safe having a BIG hot wire running to the front of a Pinto is safewas having a short wire leading to the solinoid that is hot???
Maybe I missed your point????
map351
Quote from: V8pinto_306_n2o on March 24, 2008, 02:37:06 PM
  Also, the solenoid pushing everything seemed to be a better deal (at least in my head).
73 2.3Turbo Pinto
Pinto FiberGlass
V8pinto_306_n2o
Quote from: Pintony on March 22, 2008, 11:01:29 PM
Put the solinoid at the backclose the the batt..
If the solinoid is in front then the BIG positive cable is hot all the way to the solinoid all the time. DANGEROUS
If the solinoid is in the rear only the part between the batt and the noid is Hot, except when the starter is cranking.
This is what I though too.  Also, the solenoid pushing everything seemed to be a better deal (at least in my head).  But then I wired it all up and still need the charge wire going from the alternator all the way back to the solenoid in the back of the car.  And since it's carrying current and traveling a long distance, it needs to be a decent gauge.
So you can't win with this one.  You either have a hot wire running from batt to solenoid in front, or you have a hot wire running from alt to solenoid in rear.  Either way you're live all the time.
earthquake
I also have my battery in the spare well,but only about 8 or 10 in of the cable is under the car .I'll try to take a few pics of the cable route.I routed the cable through the unibody.It isn't hard although you do have to remove a few things, but the cable has almost total protection from damage.
Quote from: woodie on March 24, 2008, 09:22:51 AM
I have a marine batterybox for a boat that I can vent out side would like to put in the rear passinger seat.
Is it a SEALED box?
woodie
watch this
My Pinto has a fully sealed and vented box.  I run two cables to the front.  One ground and One hot.  Ran them out the right front lower splash panel and through the fender well into the engine compartment.  All holes have rubber grommets.  Clean and it works or at least for me.
In addition to my posts in this thread:
I would not put the battery INSIDE the car unless it were in a SEALED & EXTERNALLY VENTED case that was designed specifically for it (unless it's an open racecar).
I feel the similar way for the gas tank. Even with the 'issues' of the stock Pinto tank, I like the tank being FULLY OUTSIDE of the passenger compartment. The only way that I would put one inside is IF it were a sedan and a full rear firewall was installed.
map351
I have my battery (dry cell) under the RT fender out of the way and i needed the 13Lb on the RT front..
73 2.3Turbo Pinto
Pinto FiberGlass
Woodie,
Ran the cable through a hole that was already there for something. Ran the conduit down in the crotch of where the inner fender meets the firewall and continued along the frame member. Ran along the front frame member till it ended and then doglegged out to the inside of the of where the floor panel is joined to the body panel. Continued back till the rear wheel well and then doglegged back inside and then up. Look at 3 and 4 pics for this. Drilled a hole in the spare tire well and slipped it in. I made sure I placed hose over the cable where they go through holes to avoid a wear in the insullation.
Quote from: woodie on March 23, 2008, 09:07:39 AM
thanks for the help would I need to vent a dry cell? do they give off any gas> that would not be good inside the car thanks woodie
I have seen where they don't, but I still would not put it under the dash. I tucked mine in the left front fender.
earthquake
I am using it so I don't have to replace them all the time cause my headers burned up the starter.It's smaller and lighter,much easier to change if they go out and removes one more item from under the hood.I guess I should say moves it.
woodie
 will the heat from the turbo kill the solenoid? if I use the ranger starter
watch this
Leave the selenoid in it's stock location if you can...but like Pintony says closest to starter. I put my bats in the spare tire compartment ( see...ThunderPinto gets and interior...in projects) I ran a large, stranded, welding cable to make sure I could carry the amps for 15 feet and put it in a peice of 1/2 inch conduit as well. The cable just fit so I had to put it together in sections. This run is not pictured in my project so I will take some pics while the car is up on jacks and post them a little later today. I grounded to the body at the rear of the car with a big eyelet,soldered on and a 3/8th nut and bolt.
earthquake
The easy way to do it is to find a mini starter from a later model ranger.The solenoid is on the starter.
woodie
watch this
Quote from: pintoches on March 22, 2008, 11:06:29 PM
I'm planing to put it under the dash to make the engine bay look cleaner
Not that I reccamend it at all, but I hope you are planning to use one of those 'dry cell' types.....
pintoches
Ches Lathim
72 Pinto Wagon
78 F150 4x4
87 ford F150
Seeing as my battery has its own battery box in the trunk of my Pinto, and the solenoid is still under the hood with the started, I'd say its safe up front under the hood, or at least that's what works for me.
woodie
 is it better to put the solenoid close to the battery or by the starter? thanks for any help Woodie
watch this
