Need Clutch & Brake Pedal
Date: 12/23/2016 06:16 pm
Date: 03/30/2021 12:29 pm
1979 Pinto Rear Bumper
Date: 03/26/2021 03:26 pm
1977 Front Sump 2.3 Oil Pan
Date: 09/14/2018 11:42 pm
Various Pinto stuff for sale.
Date: 11/21/2018 01:56 pm
Date: 07/17/2019 05:23 pm
2.3 front sump oil pan
Date: 07/24/2018 03:17 pm
SEARCHING HOPELESSLY
Date: 02/02/2017 07:21 am
oldskool787
Date: 02/12/2017 12:42 pm
  • Online today: 210
  • Guests: 196
  • Total: 196
1978 Pinto - Interior
Started by Cookieboy, March 16, 2008, 08:42:35 PM
I didn't get any time today to do what I wanted, but I did get the dash cap glued down.
life gets in the way sometimes  ;D
Lookin good there. I like your idea about 3.5's in the dash. I should do that. Oh wait a minute.. that's what I did 2 years ago. lol.
and stereo wires are run/hooked up so I tested my setup. Rear speakers are not mounted in the rear panels yet so my true sound can't be heard yet but sounds OK so far. I need to chase down a few things tomorrow before I can finish the dash, heater controls, radio, ash tray, glove box, etc... so I can't finish yet but... soon I hope.
Tomorrow I will glue the dash cap down for sure, need to replace some bulbs on the speedo cluster. And.... I have to find an  ??? antenna extension  ??? as the radio has the hookup on the wrong side  ??? this could get interesting. Also seems I have to chase down a short/ground issue as rear turn signals work but the front don't  ???
Ahhh... the fun of reassembly  ;D
Well here's Saturdays accomplishments...
1) visors and overhead light
2) lights, wipers, vent and speedo
3) other vent and test fit dash cap (not glued down yet)
4) replaced the missing seatbelt cover and rear hangers installed (Thanks Tigger! perfect match for the headliner)
Well... I did take Friday night off from the pinto.. rested up and ready to get back at it this weekend. I got the speakers I wanted for the front speaker mount. 2 - 3.5" Pyle PLX32's (nothing fancy and cheap) and will let me hook up the new stereo front channel's in stereo and mount in the original location. there will be a set of 6.5" speakers in the rear panels by the rear passenger seats. Nothing fancy here but should be enough for toolin' around town.
1) first picture is the tools/stuff I used to mount the speakers... drill bits, misc nuts, bolts and washers, an old blask t-shirt, some black glue, and of course the speakers.
2) first order of business was to drill the holes for the speakers. Then I cut a section of the old black t-shirt for the speaker cover. Taped it to the top of the box for the speakers (didn't stretch to tight) and put a bead of the weatherstrip and gasket glue down on the speaker bracket. Pressed to to the t-shirt and pulled it back off, touched up with a smaller/lite bead and reapplied. Let sit until glue was all setup. The glue used acts a lot like contact cement.
3) then I was ready to mount the speakers to the bracket. I had to use a bunch of washersto move the speakers away from the speaker base. The center tweeter on each speaker would have sit to high in the bracket if I didn't and I didn't want any issues when installing under the dash. I hope it all fits OK... It should...
Anyhow... plans for this weekend include... reinstalling the dash pad and putting the new cap on. Mount the new defrost vent plastic and my new front speakers. Reinstalling the light and washer controls, both side/dash vents and possibly the speedo cluster and heater controls and possibly start on the new radio install and other small items.
Lots to do but getting closer  ;D
Windshield is installed and with the cleaned trim and the new seal it looks sweet and I rest easy knowing the bugger shouldn't leak. George (the glass guy) told me they sealed it up tight and should be good to go. He also did me a small favor... installed my new beltlines  ;D
The new tank is hooked up, it should be a little warmer this weekend in the 40's so will be decent to work in the garage so I should be able to get a bit more done this weekend. Debating on if I want to take the night off on Friday, get a few house things done or work on the car. Think I will take the night off...
gas will be delivered tomorrow so I can keep warm...
tonight I cleaned up the trim for the windshield and stripped the center piece for the new steering wheel. I had a bit of overspray on the trim so I used paint stripper to remove and all polished up before the windshield goes back in.
I also wanted to remove the wood look to the center trim on the wheel. I got the wheel from my old mustang II I scrapped this last summer. It's black with a thick leather OEM wrap. I will paint the backside plastic with the plastic primer and then the same blue paint I used on the dash as well as the lower cover for the steering column. I will also paint the kick panels to match, I think it would look funny if I didn't so one more painting session before I'm done... details man... details... soon reassembly starts  ;D
Thanks Tony, I really do feel like someone has beat me with a rubber hose. I'm sore in places I didn't know could hurt from all the climbing around inside this car. I guess being a "computer nerd" has it's drawbacks when it comes to activities like this...
Monday was horrible and it was all I could do to get thru the day. A good nights sleep and I really felt pretty good Tuesday and was ready to hit it again last night. But after twisting and turning, tucking and pulling to get the rear gasket to fit well. The odd angles and laying on the cold floor to do parts of the door gaskets.... I could feel the pain again and faded fast.
Them gaskets I got from you (door and hatch) really look and work great. I can't thank you enough for sending them to me.
On the up-side... I can afford to take a bit of a rest for the next couple days as I'm waiting for a few things to arrive and still have a few items to prep before the next step... then back at it!
now... where's that # for the gas place  :lost:
Lots of hard work there Brian!!!
Looking good!!!!
Well... new door gaskets and rear hatch gasket are installed and fit good. I reinstalled the steering wheel and drivers seat so it's ready to go back to the glass guy to have the windshield reinstalled. After that's done the real fun begins  ;D
On another note... almost out of propane for the garage heater, started "stinking" last night. Where is Summer!!! I didn't want to buy anymore  :(
Done! Headliner installed! Now that's what I call a busy and productive weekend...
I'm gonna go collapse now.... Ohhhh... I hurt... but it feels good  ;D
Quote from: TIGGER on March 30, 2008, 04:05:08 AM
Looking good Brian.
Thanks Tigger...
boy am I sore and a bit tired but gotta keep going....
garage is heated, tape is pulled and WOW does it look nice. almost want to install a door panel just to see how it will look but have to wait.
more pics with tape pulled and wiped down.
plus the next step  ;D
Painting = Done!
gads... that took longer than expected... sanding, masking, primer and paint.
tomorrow I remove the masking to see how it turned out.
looks good so far  ;D
Friday Night! got the heater core pulled and replaced all hoses and clamps. Was even able to get "molded" top and bottom radiator hoses  ;D
Tonight... sanding and painting the interior dash and doors...
 ;D  ;D YIPPY!!!  ;D  ;D
Headliner has finally arrived and car is going to get it's windshield pulled today!
...now I can get started on the Big Stuff!
I finished painting the interior stuff last night so that is all ready to go...
I know where I'll be all weekend  :)
Thanks Tony, I really think it's going to look "WOW" when finished...
Got goodies from Fed Ex today. Some parts from Tigger I needed and my Dash Cap arrived.
Still waiting on the headliner to get here... I wanna get that glass pulled so I can get to work on the car.
been working on some of the other small parts...
here are a couple emblems that I refurbed the red/white/blue.
Hey Cookieboy,
The panels and parts look awsome!!!! 8)
That is a GREAT color and will look very nice in your White 78 all glass hatch Pinto!!!
Keep up the great work!!!!
well... with Tony's advise and help all went well with the painting I wanted to get done this weekend.
I'm still waiting for the headliner and will wait for it to arrive (mid-week) to have the windshield pulled.
left to do... not necessarily in this order.
sand and paint the dash and doors.
paint door panels and arm rests.
remove heater core to replace lines.
install headliner and new rear hatch gasket
have windshield reinstalled w/new gasket.
Install the new door gaskets.
reassemble the interior and dash
install new radio/CD/MP3 player and speakers
Quote from: Pintony on March 22, 2008, 10:53:51 AM
Mineral spirits have too much oil in it for painting.
Thanks Tony for the info and call... my mistake and I know what to do to fix...
do over...
Well There's your problem!!!!
Mineral sprits are for cleaning brushes and thinning oil based paint.
Not a suitable cleaning agent.
You would be better off with just soap and a good rinse.
Maybe some scotch brite to scuff and then a tack rag to remove the dust B4 painting.
ARGGG!!! I'm getting frustrated!
OK.. I'm trying to paint the plastic rear panels and doing some testing on small parts before I commit to the big parts and it's not working. Fish Eyes!!!!!
Here's what I have done....
clean parts with warm soapy (dawn dish soap)
clean with magic eraser
clean with mineral spirits
use "Valspar" brand plastic primer
then spray with Rust-oleum Metallic paint
and I get Fish Eyes!!!
:wow: any ideas on what I am doing wrong?
I have all the pieces needed to just put in the back panels and leave them in the original black but... everthing else will be dark blue/light blue and think it would look a bit funny/off if I do that. If I can't get this paint to stick and look nice however I will not paint them.
Thats not joke Cookieboy...I sent my Daughter to clean the inside of her car and the back panels are trashed...I wonder about this. since I have had Black ones that held up pretty good but the blue all have been compromised.
I've been kicking around doing a fiberglass and fabric covering like they do with sub inclosure's to reproduce a durable rear side panels...But then again it might be a little too much for her since she wanted to drive it last year...:)
Keep it up. your motivating me.
FrankBoss
www.PintoWorks.com
Quote from: dave1987 on March 20, 2008, 03:49:49 AM
I can't wait to see a Sprint back on the road again!
Thanks Dave, BTW it's not a sprint. Sprints were 1972 only and this is a 78  ;)
the entire interior has issues. I pulled the rear panels last night and they are just crumbling. The visors and door panels are bubbling, dash pad looks horrible, etc... once I'm done the interior will look a whole lot better and ready for me to start racking up the miles, daily driver bound this car is  ;D
Sounds like you're on a roll on this one cookieboy! I can't wait to see a Sprint back on the road again!
I have never seen door panels bubble like your passenger's side has. I've only ever seen them sag like my own passenger's side panel has.
1AAuto is great. I ordered my dash cap from them and am VERY pleased with speed of service and quality of product!
another update - gathering the interior parts and taking inventory. found the last couple items I was looking for tonight. I'm thinking I will spend the weekend getting all the interior parts cleaned and painted. It will be next week before I get the windshield pulled and so I can park the car outside to make room in the garage for painting.
I also removed the original rear panels. Tested to see if the new rear hatch gasket will work as good as the door gaskets did and all is cool. I have done partial cleanups of most in the interior parts but still more to do.
I need to run to the store to get some more of the items needed for cleanup/prep the plastic and vinyl parts I will be painting. Also need to get some sand paper for the dash and doors before I can paint them. I am planning to sand and paint after the windshield is pulled and before the headliner goes in.
Quote from: TIGGER on March 18, 2008, 10:25:21 AM
Brian, make sure it is nice and warm when you install the headliner.
Thanks for the tip Tigger, I have to heat the garage anyhow so all will be good there.
Update... Dash Cap Ordered = Found on Ebay and called to order direct 1Aauto
cost was $57.95 and $28.00 Ship = $85.95 Total
Web Site = http://www.1aauto.com/
Ebay user name = www.1aautomotive.com
Phone = 888.820.3393
Brian, make sure it is nice and warm when you install the headliner.  It will make the job much easier and look much nicer.  I installed the headliner in my 67 coupe years ago.  My first attempt was in the dead of winter when it was real cold out.  I could not get the wrinkles out for it to look good so I quit.  The next term started shortly after and I did not have time to fool with it again till spring break.  I picked a nice mid 60's day to do it the second time.  WIth the car outside in the sun, the headliner went in like butter.  It was amazing how much the difference in temperature made.  The only thing I had trouble with was doing the curve around the back window.  My neighbor, who does interiors for a living, helped me with that real quick.  To this day, the headliner looks just as good as the day I put it in.
Funny enough
My Daughters car is the same colors..and we're starting the same project this summer....
So far we need high back seats and the back plastic.. I figured we would cover the plastic with a tweed or vinyl to cover the age/color and damage.
FrankBoss
www.PintoWorks.com
Update....
Looks like I get to try my hand at installing the headliner. The gal I had hoped would install/teach me how well... she doesn't have the time to do it right now due to medical issues with a family member so.... Last night she walked me thru the process and gave me lots of pointers. I did get to see the finished one on the 73 and I do remember lots of the details. The only real question I had was how to do the part above the driver/passenger doors and now I have the answer. She will help if I get really stuck but I really think with what she told me/showed me last night I should be able to do it.
I think I can! I think I can! I think I can!
This morning I stopped by the automotive paint/restore store we have local here in town (village glass) and they have all kinds of neat items for restoring cars. I got some of the push pins needed for doing door gaskets, some vinyl prep/cleaner for the door panels and they had some lite. blue paint for vinyl that is an even better match than the blue I already had. Plus it's for Vinyl! I also found they have the push on washers/lock nuts needed for the heater control cables. Yippy!! I needed some of these and haven't been able to find them.
Anyhow I have to order the dash cap today and consider when I will have the windshield pulled - this week vs. next week. I would like to wait for the gasket and headliner to arrive before I do that and hope they will both be here late this week.
Other than that been cleaning up the stuff for the dash - vents, heater controls, kick panels, radio bezel, in other words all the plastic up front. All of it was pretty clean and not much will have to be painted. I decided against ordering the leafing pen. I'm happy with the way the silver sharpie looks when finished. Seems to hold up fairly well and is easy to fix if scratched, plus I already have the pens required so I don't have to order, pay and wait.
I'm not really looking forward to doing the rear panels, they are BIG! and will require lots of cleaning. If I want the paint to stick well lots of prep and cleaning are required.
