77 pinto cruz. wagon
Date: 06/15/2017 09:18 pm
Date: 11/14/2019 04:02 am
77 Wagon rear hatch
Date: 12/04/2019 05:57 am
Date: 06/18/2018 03:47 pm
1978 Squire wagon 6 Cly
Date: 02/16/2020 05:42 pm
Date: 03/29/2019 07:20 am
1971-74 Various Pinto Parts
Date: 01/18/2020 03:44 pm
1980 Pinto Pony for sale
Date: 08/21/2021 03:54 pm
Date: 01/28/2019 05:15 pm
  • Online today: 600
  • Guests: 366
  • Total: 366
1978 Pinto - Interior
Started by Cookieboy, March 16, 2008, 08:42:35 PM
Quote from: dave1987 on March 17, 2008, 01:28:14 AM
Keep the pictures and updates coming!
sure will....
glass guy is onboard, stopped by this morning and he's ready when I am. Headliner gal will stop out tonight and based on when she will have the time to install it the project will get underway.
Also... since I have the dash pulled I will be pulling the heater core and replacing the hoses to it. Looks to have the originals from 78 still on it and so.. well... might as well.
This morning I had a thought about my interior door panels...
Since I'm concerned with the door panels matching the rest of the paint and seats.... Finding the correct vinyl could be difficult. Passenger door panel is shot and needs replacement and I also have a replacement arm rest for the driver door but it's red.  I do have a baby blue paint that matches the seats well and a set of door panels in light brown/beige from the 73 so....
I was thinking to paint the door panel from the 73 passenger side in the baby blue. Repaint the current driver door panel with the same baby blue so they both match. I will have to paint the red arm rest to match so might as well paint both so again they match. Then I was also thinking to paint the outline in the center of the door panels in the dark blue to add a little "pizazz" or help blend the baby blue into the dark blue that I'm switching to. see pics below... color isn't exact but you get the point  ;D
I don't really like the idea of painting all this stuff (door panels and arm rests) but it's either that or find a replacement passenger door panel in baby blue and a drivers arm rest in the same baby blue color.
~or~
Find 2 replacement door panels and arm rests in the darker blue.
I'm just trying to get by for now on the door panels and seats so none of this has to be something that will last for years and years. Right now cheap and easy is the goal when it comes to the door panels and arm rests.
Tip of the week! All Fords I have worked on have a .040 /.060 dia hole in the rear end breather fitting. Over the years this will plug up and cause the grease seals to leak. Presure has to go somewhere. Simple fix is to drill out the breather fitting with a .125 dia drill and the problem is fixed forever.
I'm looking forward to seeing this one completed. A lot of what you are doing are things I've done to my own 78 Sedan, or I plan to do (like repainting the dash and putting up a new headliner).
chrisf1219
hey cookieboy looks like you got a nice project going there. i wonder how many doz of cookies it will take to finish it? ;D make sure you got plenty of ca. raisins in those oatmeal cookies . see ya chrisf1219 in ca.
more pics...
well... it's been running great and so far and I am happy with the mechanicals since I had the rear axle seals replaced and brake hardware changed. I was just going to replace the door and rear hatch seals/gaskets (Thanks Pintony!) but noticed that the headliner gave way (see picture below) so my plans to do the interior and windshield gasket have been moved up.
Some may recall the story went something like this... car sat for many years in the hot Nebraska sun and the interior literally baked to the point most of the plastic interior stuff just crumbles when you touch it. The rear panels are so brittle I can poke a finger thru them w/o any real effort, some of the duct work (defroster piece) have just crumbled and is held in with tape. Headliner and seat seams are coming apart.  I also have minor issues with painted surfaces. Someone long ago removed a sticker (or something) from the glove box door with a razor blade I'm guessing as the paint is gone. The interior of the doors were painted a non matching color and there is a lot of over-spray from the Macco paint job it received. I knew I was going to do this... was just hoping I guess to put it off for a bit longer is all.
Once the headliner dropped... I decided to go ahead and get it all done now.
So... here's the plan.
1) I ordered the front windshield gasket and beltlines for the doors (Autokrafters) and a new headliner (Headliner Mart) in dark blue instead of the original light blue.
2) The gal that installed the new headliner in the 1973 is coming by Monday night to look it over and I have already asked her if she'll do this one in my garage and show me how. I can only hope she will still agree to that after she comes on Monday.  ;D
3) Talk to the glass guy I do business with and setup the time to have him pull the windshield to make things easier to install the headliner. Gasket needs replacement as it is split/cracked and leaks bad so perfect timing.
4) With the windshield removed it will be the perfect time to sand and repaint the dash (Rust-oleum cobalt blue metallic) which from my test spray is almost a dead-on match for the original color but has a little bit more flake in it. I will also be repainting the interior of the doors to match the dash removing the original baby blue (Yuck!)
5) Another issue is the rear interior panels, brittle and crumbling. I have a spare set from the 1980 I scrapped last winter, they have holes cut for speakers and are black but in good condition so they will be used. I will paint them the same colbalt blue metallic the doors and the dash will get, the main reason I chose to go with the darker headliner as it looks to be the easiest thing to do and keep the colors matching. I will use plastic primer so hopefully the the Rust-oleum with stick good to the rear panels.
** I am hoping to keep the colors the same thru-out (dash, doors, rear panels) so I want to use the same paint - color - brand and hope the plastic primer will work as advertised and good. I know prep-work here will make the biggest difference so I will do my best.
6) Replace any duct work (defroster) that needs it (replacements from the 1980 I junked)
7) Cleanup and referb the plastic items on the dash (vents, heater controls, speedo cluster) and am considering ordering the leafing pen to re-do the chrome trim.
8) Install a new radio with CD/MP3 playback and speakers as the rear panel holes already cut. May consider door speakers as well.
9) still trying to decide dash cap (most likely) or vinyl for the dash. Ohhhh... it's ugly now.
10) I will need to find vinyl for the door panels (may have found something at Wal-Mart today) that will work. Passenger door panel has issues and looks terrible. My biggest problem/concern here is that I'm changing the color scheme from dark blue/baby blue to more dark blue and trying to eliminate the baby blue. Color matching here will be tough.
I will be using the original seats in baby blue as they still look OK and I really don't want to spend the money right now to have them recovered. Now would really be the best time to have them recovered so I can use the same vinyl on the door panels as the seats have but I just don't want to spend the money right now when it can wait. Perhaps next winter.
I also have a center console from a 76 Mustang II I want to install in this car. Not sure if I will paint it or possibly recover w/vinyl... still considering here...
Anyhow... I spent the night last night doing the initial tear-down and am ready for her to come see the headliner. Last time she installed the one in the 1973 but it was removed before I bought the car so she did it blind. This time I want her to see it intact so I have left all the rear panels installed and haven't disturbed it so she will know what we are starting with.
now for some pictures....
