Date: 11/05/2016 09:03 pm
TWM Intake
Date: 08/15/2018 08:20 pm
Interior Parts
Date: 08/07/2017 03:59 pm
Date: 10/02/2017 02:16 pm
Date: 02/10/2017 09:30 am
Pinto Wheel Well Trim
Date: 03/29/2017 11:35 am
Weber dcoe intake 2.0
Date: 08/01/2018 01:09 pm
Date: 04/24/2018 11:45 am
2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
  • Online today: 489
  • Guests: 352
  • Total: 352
engine swap
Started by losin sux, June 30, 2004, 09:33:35 AM
vbmdu
Quote from: losin sux on July 01, 2004, 08:33:49 AM
Looking at that again it is kind of murky huh?  If I initially purchase a car with a 2.8 but want to put a 2.3 stock in it will I have to bring the 2.3 wiring harness over from the donor car?  I will EVENTUALLY want to go with the EFI 2.3 Turbo out of a SC or Merkur etc.  This would be done in stages if you get my drift.  That make better sense?
I think if you're just putting in a stock 2.3, nothing really changes except for maybe the ignition box. The sending unit wires and alternator would be the same I would think. You can install the 2.3 turbo wiring when you put that motor in.
CHEAPRACER
Well I would say if this was a Chevy truck, you just unbolt the harness from the outside and transfer the new one. Since this is a Pinto and removing the harness is a pain in the @$$,  I would say use the old one and make little modifications as necesary.
losin sux
77 HB 2.3 C3 3.40
CHEAPRACER
I'm not sure I understand your question but if your using an EFI Turbo 2.3, you'll need almost every part of that harness. I used an 88 Turbo Coupe donor car with every option. I'm conviced I think they ran even the radio antenna wire through that thing. I chucked the ECM plug in a vise and started undoing the outer cover until I had every wire seperated, then removed all the unnecesary junk until I ended up with a clean harness. There are books & internet info on wiring diagrams & pinout on the ECM that are very helpfull.
losin sux
Curious about a swap from a 2.8 to a 2.3 (think turbo)and the wiring harness.  What might NOT be on a 2.3 that would require me to bring the harness over with the engine?  Ideas, thoughts and comments please.
77 HB 2.3 C3 3.40
