1977 Pinto for parts
Date: 10/10/2018 06:25 pm
Date: 07/04/2022 07:55 pm
71-71 speedo cable
Date: 07/31/2021 09:04 pm
Date: 03/15/2023 02:16 pm
74 hood
Date: 07/03/2017 03:46 pm
71-73 Pinto Parts
Date: 06/06/2019 10:47 am
FREE PARTS!!
Date: 01/10/2017 02:38 pm
Pinto Parts for sale
Date: 06/19/2017 02:01 pm
  • Online today: 1,185
  • Guests: 607
  • Total: 607
FAQ: Rear End Ratios
Started by Poison Pinto, June 28, 2004, 08:17:00 PM
steveo
HI
I have a rear end with tag numbers that read  WGF-AL-7J6
It came with but not in the pinto i just bought, and i haven't been able to find a code that matches it.  Does anybody know what this code is for or what it might be out of?  it looks like a 6.75"
thanks
straw boss
If you do that, you must make sure both tires turn exactly the same amount, or your reading will be off.  If the rear doesn't have limited slip, one wheel can lag behind the other when you are turning the driveshaft.
What I have done when that is a problem is lock one wheel so it can't turn, then count the turns of the driveshaft to make the other wheel turn two revolutions.  Sounds weird, but it works.
PintoBro
If the tag is missing, or you suspect that the rearend has been modified, another way to tell the gear ratio is by jacking the rear of the car up, and put it on jack stands. Then mark one of the tires and the driveshaft. Slowly rotate the tire one full revolution, while counting the revolutions of the driveshaft. If you get 3 full turns of the driveshaft to one full turn of the tire, you have a 3.00:1. If you get a little over 4 full turns of driveshaft to one full turn of the tire, then you probably have a 4.11:1 ratio. This method is not exact, but it will get you in the ball park.
Pintobro
71 Pinto 306 10.0:1 351w heads
Comp Cams: .554/.558 lift .294/.306 duration
Torquer II Intake - Holley 750 HP
Sepanek's Racing Transmissions C4 (Full Manual)
8" rear (4.62 spooled)
Poison Pinto
One frequently asked question is how to tell what the gear ratio of the rear end is. This is especially true if looking at a rear end that is out of a car or if you know that the rear end in a car is not the original unit. Provided the rear end itself has not been modified, the following information should help you determine the gear ratio of your rear end.
The rear end case should have a small metal tag. On the 6.75" differential, this is on a bolt that holds the back cover on.
The tag has several codes on the top and bottom edges.
The easiest method is to look at the numbers on the bottom edge. This is useful if you're looking at a non-Pinto rear end (such as an 8" rear end out of a different Ford model).
Example:
3     40     #   #     ####
This indicates a conventional 3.40:1 ratio.
Limited-Slip/Traction-Lok differentials will have an "L" between the numbers.
Example:
3 L 40     #   #   ####
The original 6.75" rear ends put in 4 cyl and some 6 cyl Pintos have codes along the top edge that should comply with the following:
1975-76
C2-WGF-H or -K ..... 3.40:1
C2-WGF-U, -R2, or -AA ..... 3.18:1
C2-WGF-N or -R ..... 3.55:1
1977-78
C2-WGF-KI, -UJ, or -AA ..... 3.18:1
C2-WGF-AJ ..... 2.73:1
1979
C2-WGF-AM ..... 2.73:1
C2-WGF-AN ..... 3.08:1
C2-WGG-C ..... 2.73:1
C2-WGG-D or -E ..... 3.08:1
The "C2" in the code denotes a conventional rear end.
Sources: Haynes Auto Repair Manual for 1975-1980 Ford Pinto & Mercury Bobcat; www.mustangii.org/decoder/axle.
