Date: 01/06/2017 11:42 pm
Date: 03/25/2019 09:02 pm
Date: 03/14/2020 01:52 pm
A.c. alternator hrackets
Date: 09/03/2017 12:11 pm
windshield
Date: 04/14/2018 08:53 pm
1978 pinto grill
Date: 07/24/2018 02:18 pm
1980 hood needed
Date: 04/23/2020 10:41 pm
1976 Ford Pinto
Date: 07/16/2019 02:51 am
Sunroof shade
Date: 06/19/2019 01:33 pm
  • Online today: 1,972
  • Guests: 1012
  • Total: 1012
FAQ: Rear End Ratios
Started by Poison Pinto, June 28, 2004, 08:17:00 PM
As noted a number of posts earlier the first number is often obscured by either the bolt head, or "gunk" build up around the bolt.  Being there is no 2:18 or 4:18 I'd feel 99.9% confident that you have a 3:18 (based on the 1867 ... you provided) which was only available in the 6-3/4" rear end.
fastfred
The tag on mine at the bottom reads 1867 224A.  The high one looks like FU-5FC with perhaps something before this!
Fred
  A men brother! I've been in the same boat as you have.
It was interesting as I looked for internet information to support what I had posted. Those with limited slip rear ends posted the method you had (which is correct) and those with open rear ends posted what I had (which is also correct). What I did NOT find find was any posts stating 'there are two methods, for two different rear end types.' Thus it seems that whatever method people had used at some point in their life..., they thought applied to both.
But, yes, I learn new things all the time (or learn I was was wrong). Sometimes to my embarrassment, but ultimately for the long term betterment.
BTW, to the original 'how to tell' question above?  If you jack up one wheel and the tire rotates you have an open rear end and use the "open" method listed above. Note that the car needs to be in neutral and the brake off so properly secure the car from moving/falling on level ground.  If the tire will not rotate you have a limited slip/posi traction type rear end and need to use that method listed by Dick above.  This will require both rear wheels being off the ground and thus it only increases the need for the mentioned safety aspects.
As Paul Harvey use to say, "And now you know the rest of the story".
Quote from: dick1172762 on December 13, 2017, 09:44:09 AM
But if you have both wheels off the ground, the spider gears would not come into play or would they?
My experience is that:
1. Most cars have an open rear end.
2. Most people prefer to (or, only can) jack up one wheel. And with the open rear end it is necessary.
Hence the one wheel fixed, two wheel rotations method.  Regarding both wheels off the ground in an open rear end situation, yes, that becomes difficult. I've tried doing that in the wrecking yards and as one brake may rub over the other the spider gears come into play and skew the driveshaft rotation count.
That is why one wheel locked down makes for a consistent result.  That can be difficult to accomplish in the yards. I've tried jamming items in wheel openings, stacking tires until they jam and even turning the brake adjusters (one tight, one loose) to accomplish the task.
As you have stated it is both wheels off the ground and one tire rotation to driveshaft rotation count IF the rear end is limited slip/locker etc.
Dick, you have had too many (race) cars with limited slip rear ends.  When the rear is open the spider gears come into play and the driveshaft rotation is half. The easier solution is to just turn the wheel twice and measure the driveshaft turns.  http://www.mossmotoring.com/the-highs-and-lows-of-differential-gear-ratios/
Or, the relevant part there of:
The easiest way to determine the gear ratio is to jack up the car (safely) and block one rear wheel so it can't rotate. Most British cars have "open" differentials, where a spider gear causes the wheels to rotate opposite one another. If you block one, the other wheel spins twice as quickly. When driving, this allows the wheel on the inside of a turn to rotate slower than the one on the outside of the turn. With the transmission in neutral, rotate the unblocked wheel two full turns and note how many times the pinion flange of the differential rotates. Marking the wheel and flange with a white marker helps keep track of the rotations. The number of turns is the gear ratio, which is called out as number of turns of the differential pinion to one turn of the axle.
open = two wheel turns
limited slip (etc.) = one wheel turn
Not double. If you rotate the tire one turn and the drive shaft turns 3 turns, you have a 3:00 rear end. If the drive shaft rotates 4 turns you have a 4:00 rear end. Etc, etc. Using this method you will see its very hard to pick out a 2:93 or a 3:18 from a 3:00 gear. If you take the rear end apart, it very simple to check the ratio by dividing the number of teeth on the pinion gear by the number of teeth on the ring gear. (the small number divided by the large number).An example would be 6 teeth on the pinion and 20 teeth on the ring gear would give you 6 divided by 20 and a ratio of 3:00. Easy as pie!
No, the code as far as I know is not in the VIN. You have to look at the tag on the axle..., and as Dick stated it still might not be that ratio - but hopefully is.
As far as the tag in the image it was not cleaned sufficiently. The area I circled in red is the ".18", and the dirty area in blue I circled is likely where the "3" is.  As for your own car you will have to crawl under and clean/read the tag (safely secure the car before doing so). I've included a 3.00 tag as an example of the how far the "3" number is close to the bolt hole.
There is a mean by which one can rotate the tire and count the driveshaft rotations but in an "open" rear end the true count is double the drive shaft rotations and subject to misreading. If for some reason the tag is missing you will need to do that as a way of getting "close."
FWIW if I was choosing a rear ratio and my choices were factory only it would be either the 3.18 or the 3.40. Most likely 3.18 if I was using 13" tires and a fair amount of highway driving and 3.40 if I was using larger tires and perhaps inclined more to city driving.
Crazy Lacy
Join my - Pinto Ford USA - on Face Book.
William "Crazy Lacy" Furmage
Original Vans BMX Freestyle Pioneer 1982
Do know that your tire size is as much a "gear ratio" as the gears themselves. Here is a calculator link that can be very helpful http://www.wallaceracing.com/calc-gear-tire-rpm-mph.php
I quickly ran a few tests at the Federal 65 MPH speed limit. Here are the results:
3.00 gears, 24" tire (likely a 13")        = 2,730 RPM
3.40 gears, 27" tire (likely 15" or 16") = 2,750 RPM
So, as you can see there is only a 20 RPM difference at 65 MPH between 3.00 and 3.40 gears because the tire size became the great equalizer. And just to prove the point:
3.40 gears, 24" tire (likely a 13") = 3,094 RPM
Not altering the tire size made a 364 RPM difference. That is significant. Thus, know your goal.
  I have a 2.3 Turbo in my car with a very low 3.97 first gear (T-5) and a 3.40 rear gear. With the 175-70-13" tires I find it too low.  Previously I had the same set up with 3.00 rear gears and the 215-60-`14" tire.  I actually liked that for acceleration as it gave longer "pull" time between gear shifts with the turbo. HOWEVER, for everyday driving it was awful. The car was always in the wrong gear for normal everyday speeds. As an example 45MPH was too wound out in third gear but too bogged in fourth gear. Therefore the 3.40 gears were better in that regard because it put the engine in a 'sweet spot' for the speeds posted even though it came as a trade-off for the low (too low for my liking) first gear.
My opinions are a bit altered because of the Turbo motor but I'd think about 3.25 is a good overall ratio with 13" tires. And because I'm accounting for more highway driving than scooting around town my numbers are different than Dick's. As to the tag posted I'm thinking you are missing the "3" in a 3.18, 6-3/4" rear.  If you are running 13" tires and do a fair amount of highway driving it should be acceptable.  BTW, what ratio do you have now?  It would be good to know so you have a point of comparison.
I have no idea about what ratio is in the one pictured. If it has been changed along the way it could be any ratio. Taking it apart is the only way to know for sure.
Crazy Lacy
Is the one you're saying is the good one to have, the one I'm asking about ?
Thanks for input  8)
Over the years I've tried just about every gear ratio that you buy from 3:00 to 4:69. On one of my 80's Pinto I had a 4:11 gear in it and around town(Denver) it was great. The ratio of 3:55 looks like the best because it is good from a dead stop and will be just right for city driving. Too low? No because how much of your driving is going to be on the interstate? Around town it'll be just right. Try it / you'll like it!
Crazy Lacy
There's one near me for sale that has Code 1867 207A, it's that any good? My rear end on my 4 speed 72 sounds like it's howling . The r-end for sale near me
For the Ford 8", the ratios 3.25 and 3.40 are still available new.  Maybe scarce in the junk yards.  The second link does not function as is, it needs to be copied and pasted to work.
http://www.summitracing.com/search/department/drivetrain/section/differential-rear-end-components/part-type/ring-and-pinion-gears/axle-model/ford-8-in?keyword=ford%208%22%20gear
http://www.yukongear.com/PartsList.aspx?SearchMode=Cat&CatID=35&CatName=Ring & Pinion Sets&MakeID=2&MakeName=Ford&ModelID=275&ModelName=Mustang&Side=Rear&DriveType=RWD&DiffID=160&DiffName=Ford 8"
cromcru
i have one 3.25 ratio or my 8 inch rear end. not selling
From my experience these cars would benefit from having a 3.25 as an overall best ratio.  Sadly (in the 8" type) you have 3.00 and then jump to 3.40. And I have found the 3.40 very hard to find. They all seem to be either 3.00 or 3.55. I did the turbo swap so an 8" is essential. Otherwise the 3.16 / 6-3/4" seems a logical choice. Ford actually did use a 3.25 for a very short time.  This from the guy who was pillaging all the 8" rears and I fortunately happened beat him to the one I got.
Tom
americanpintobean
I have a rear end tag that says WGF-K, which means it should be a 3.40:1, but the numbers underneath are 3 18 xx xxxx
americanpintobean
I would like a posi 3.55,  6.75 rear end/axle for a pinto.  Can someone help me out?  Please help
Are those door post sticker codes in the previous post?
I have a '79 wagon that says AX=Y on that sticker. I'm 99% sure that it isn't posi.
billnall
FORD CAR REAR AXLE DOOR CODES for locking/limited slip
If it is a number from 1-9 it is not locking/limited slip.
YEARS 1980 Pinto
Z=3L08
YEARS 73-79
C=2L47
H=2L73
J=2L50
P=3L40
W=3L45
X=3L55
YEARS 69-71
W=4L30
Y=4L11
YEARS 69-79
K=2L75
L=2L79
O=3L00
R=3L25
S=3L50
V=3L91
Ford Parts Man
billnall
1980 Ford Pinto rear end tags decoded from Ford Parts Catalog.
WDY-AS=2.79 - 8"
WDY-AT=3.00 - 8"
WGF-AM=2.73 - 6 3/4"
WGF-AN=3.08 - 6 3/4"
Ford Parts Man
ernie
I have a 1980 with a tag that says WFG  AN  3.08 that i am selling.  I noticed others saying tag is WGF?  are there 2?
Pretty sure the rear axel tag would say WFK... if it were a Posi.
Besides the L that would be in the 3l.40 which is sometimes crushed by the retaing bolt.
I just "SCORED" a rear from a 78 cobra II, as well as the front and rear sway bars and assorted parts. The rear has a tag:
wdy oaan 7jd
40 8 244c
I am assuming that it has 3.40 gears (I know it is an 8 inch), am I correct? I did check the rotation and it seems to be about that for sure (spining both hubs at the same time).
Boy I want the whole car, still has the engine/tranny, but the car is soooooo rough.
I plan to transplant the meatball into the 68 rear I have in the pinto (it currently has 2.79's), It should fit... right???
billnall
WGF-AL
3.18 6.7
1978 PINTO 3.18 RATIO 6.75 RING GEAR 23 SPLINE AXLES
Ford Parts Man
steveo
It looks like  18 6 7 224C    it's a little hard to read, but i'm pretty sure that's right
billnall
What is the 2nd line of numbers on the tag?
Ford Parts Man
