Date: 04/28/2018 04:12 pm
Date: 12/10/2017 01:14 pm
Date: 11/04/2018 02:34 am
Date: 10/04/2019 08:43 pm
Free 2.0L Valve Cover
Date: 01/03/2023 04:27 pm
74 4 spd and rear axle
Date: 09/26/2018 03:51 pm
Bumper Guards
Date: 03/28/2017 09:27 pm
13" Style Steel Trim Rings
Date: 10/09/2020 10:35 pm
Clutch Cable Needed
Date: 04/03/2017 10:54 pm
  • Online today: 515
  • Guests: 314
  • Total: 314
More boost?
Started by 2point3turbo, February 18, 2008, 11:49:08 PM
Try Turboford.org....You could mod a 5.0 AFPR to run a 2.3 Turbo......
2point3turbo,
The folowing is based on reading past posts and not from experience.  I believe Brad has set up his computer for the larger injectors, either a reprogrammed chip(?) or presently a programed Mega Squirt.  I suspect you will need to set up your computer for the larger injectors for best results.  Adjusting the fuel pressure down in order to run larger injectors with a stock programmed computer is not optimum.  Using a FMU to get more fuel from the 35's may push a stock fuel pump past its limit at 20psi+ boost and does not give good air fuel ratio control.  Using a wide band O2 sensor is useful when going beyond the factory stock operating parameters.
I have an adjustable pressure reg on my car and to be honest I really didn't need it. My injectors are 52s and it runs fine at 40lbs.
2point3turbo
I have both 42# and 35# injectors and want to ask about a adjustable fuel pressure regulator. Can I use an adjustable one that fits a 5.0 cause they are on ebay but cant find one for the 2.3. I want to run 20psi+ safely and want to know the best route. Should I just use the FMU setup or AFPR? I have had work done to the head such as porting, cam and what not so I want to push more air now/more hp. Need to know what to set the fuel at. I know I will have to lower the pressure for the 42#ers but do I even need them yet? Thanks in advance.
