Crane Cam
Date: 02/26/2018 07:50 am
Date: 02/26/2017 03:22 pm
Date: 09/26/2019 05:31 pm
Date: 11/29/2018 10:26 am
1977 Pinto for parts
Date: 10/10/2018 06:25 pm
71-73 Front Kick Panels
Date: 04/25/2021 07:24 pm
Date: 12/04/2018 07:40 pm
Date: 05/24/2020 08:19 am
  • Online today: 529
  • Users: 1
  • Guests: 288
  • Total: 289
  • TommyT
Clutch is done, what fluid to use in 4spd?
Started by TIGGER, February 17, 2008, 04:02:24 PM
Quote from: Pintony on February 17, 2008, 07:31:09 PM
IF you are using the t4 use transmission fluid
So, would that be the Borg Warner T4, or the five speed automatic?  :lol:
Hummer, I pumped in gear oil.  Thanks Pinto
I use 75W-90 in my tranny as well as the rear differential. I would also be interested in knowing EXACTLY what type and weight of oil to use in my tranny and rear end.
Hello Tigger,
If you are using the cast iron Hummer use gear oil.
I got my clutch done.  All that is left is to fill the transmission with fluid and adjust the clutch.  I drained as much fluid out of the transmission as I could when it was out.  What came out didn't look like gear oil.  The owners manual said use manual transmission oil ford p/n blah blah blah.  I have pretty much always used gear oil in all my older cars but this time I wonder.....
