WANTED Hood Prop Rod
Date: 01/17/2017 02:47 pm
PINTO TRUNK LATCH & CATCH
Date: 03/23/2018 09:39 pm
McLeod Clutch
Date: 04/12/2017 12:08 pm
74 Pinto Rear Side Lights
Date: 02/18/2017 05:47 pm
1972 pinto grill
Date: 02/27/2018 12:13 am
Date: 08/02/2019 04:18 pm
Date: 08/17/2022 06:27 pm
New cam
Date: 01/23/2017 05:11 pm
1974 Pinto Door Handles
Date: 03/07/2017 04:06 pm
  • Online today: 447
  • Guests: 373
  • Total: 373
Cowl access - to clean out debris
Started by Wittsend, February 08, 2008, 09:52:51 PM
ray4fords
Quote from: Pintony on February 08, 2008, 10:01:49 PM
OK Wittsend,
This is not as good as removing the fenders,BUT, If you remove the inner splash you can reach up and pull out the BIG stuff clogging the drains.
I did this on a C. wagon I had and let me tell you I used a garden hose with a squirter nozel.
I did this on a concrete driveway and was there for several hours. First squirting from the drivers side and then from the passengers side.
As I was on concrete I could see the derbis that kept coming and coming from the drains each time I changes sides.
When you think you have it all be sure to give the back side of the fenders "Where all the junk is goiing" a good
power wash too.
After you think you have it all out maybe then drive to the local car wash and drop a few bucks in quarters. :D
starkey and hutch
i did mine in the car with my hands and
bent tooth brush which i bent with heat from a heat gun. Also a vacuum cleaner with just a hose you can bend the hose to get everything around the lip worked great but removeing heater , ect was work...........
waldo786
They make those cowl covers someone mentioned.  I have one for my 66 Mustang and not sure how similar in size the cowls are but it might be worth looking into.
Well..., I got inside the cowl area today.  The good news the debris was less than I thought.  The bad news is the driver's side vent opening was rusted.  A few things seem strange.  One, the rust was part way across the bottom (that makes sense), but it was rusted more severely on the entire vertical edge closest to the steering wheel. That doesn't make sense. The rest of everything is fine. No rust issues.
  The other strange thing is my car has the front end pointed downward (slopped driveway, car backed in) and logically the water should have gone out the drain long before it migrated up hill and leaked through the rusted vent access.  I say that knowing there was debris under the cowl, but it was far less, and far less compacted than I thought. It should have drained. The nearest windshield drain hole seems too far away to provide the source either.  Nothing under the dash indicates that the windshield gasket is leaking.
  Anyway..., what a "joy" it is to work under the dash. Welding and grinding is the worst. The blood runs out of your hands, everything falls on you.  I had an old mattress pad and cardboard down and when I started to MIG in a patch panel - of course it caught on fire.
   I hate welding sheetmetal (at least with a MIG)!!!  It warps and pulls away. Clamping was not easy with the limited access. No matter how clean you get the old metal it still isn't clean enough and you blow holes in it (and to think the whole idea is to get rid of the holes). The welds come out looking like knotted rope.  I spent more time putting in a "L" shaped patch 3"x4" than I did making and replacing the whole front passenger floorboard.
  After that I'm really looking forward to the passenger side - not.
Tom
Remove the hood hinges for access to that area.
Quote from: Wittsend on February 08, 2008, 10:15:31 PM
Pintony,
  Thanks, I just remembered I have a pressure washer.  Hopefully it won't take the paint with it.
  I think there is a real market for a flexible, magnetic screen that would fit over the cowl. Something like refigerator door magnets with a screen attached and rubberized so as not to rust.  Two or three sizes should fit most every car.
  I've got one space in my garage and the Sunbeam Tiger gets it. The rest of my fleet (Pinto = #9, and oh, isn't the wife happy about that) are all outside with many trees on the property.  I could start a garden club with the "mulch" I pull out of my cars.
Tom
2 words for you Car Cover x-9
Pintony,
Tom
OK Wittsend,
power wash too.
  In a previous post I inquired about water leaking into the front of my Pinto.  I pulled the trim at the bottom of the windshield (thanks everyone for the tip about the two screws). That area actually looks very good.  I did take a flat punch and elongate the drain holes so they are flush with the bottom area to remove all water getting in there.
  We had a recent rain and I had the front windshield area covered with plastic.  While it didn't keep all the water off the windshield it kept most.  I still found water in the car the next day.  I am now at the point where I'm suspecting the water is coming in through the interior vents. When I peer into the cowl area I see a lot of debris.  Perhaps this is damming up the water and having it get into the vents?  The problem is, on the Pinto the cowl vent is not removable. Therefore, getting the debris out will not be easy.
   It seems I have two options, remove the front fenders (I don't want to do that) or remove the interior vents and reach in with my hands (I'm a thin guy - with even thinner kids who owe dad a favor) and hopefully remove the debris.   I tried blowing the stuff out with a leaf blower, but it has become a "Bio-mass" locked together for some time. I'd rather not try water.  Then it would likely clog at the bottom of the fenders.  Any other thoughts?
Tom
