Clutch Cable Needed
Date: 04/03/2017 10:54 pm
Looking for front seats
Date: 08/10/2021 09:54 pm
2 liter blocks and heads
Date: 03/28/2018 09:58 am
Date: 05/21/2019 11:50 am
McLeod Clutch
Date: 04/12/2017 12:08 pm
Date: 10/24/2018 07:41 am
Date: 04/08/2018 05:47 pm
Date: 07/17/2019 05:23 pm
Date: 09/06/2020 01:57 am
  • Online today: 427
  • Guests: 370
  • Total: 370
Hello fellow keepers of the flame-A long one from the new guy-71HANTO
Started by 71HANTO, January 24, 2008, 01:33:26 AM
I got some important things done since my last post that I can check off my list getting ready for Dearborn in July. I finished all the mounting points for the Lexan windows. A big job to get everything flush with all the compound angles of the window frames. The headlight buckets are one of the worst aerodynamic features of the car as they trap air like little parachutes causing a lot of drag at higher speeds. I decided why fight it when I can take advantage of the pressurized air to cool the brakes (plus less dust up high). So here's my solution. I used hot water heater vent hoods (Home Depot) and plastic 3 inch, 60 degree bend air intake piping (Kragen Auto). I topped it off with motorcycle headlight rock guards. I will be running 3 inch brake cooling hose to a housing that encloses most of the brake rotor.
Quote from: bbobcat75 on March 17, 2014, 09:02:13 AM
IS THAT THE FRONT SPOLIER YOU GOT FROM ME? LOOKS AWESOME!!!
Hi bbobcat75,
I did not end up using the one I got from you. I bought a larger one and figured bigger was better for most of the smaller (slower) twisty tracks I race on.
Quote from: dick1172762 on March 15, 2014, 12:14:24 PM
You've gone this far, so why not glass bumpers? Car looks greeeeeat. Keep up the good work.
Thanks, got it covered. I also want to fab some bumper brackets out of aluminum as the originals weight a ton. My mantra is: "if you want to go fast, add lightness"
Well, the glass work slowed me down on the HANTO but I see the light at the end of the tunnel. It's starting to look like a race car. Getting closer to paint. A lot of hours went into fiberglass body panel fit. The front air dam went on last evening after work but still needs a little adjustment and some support bracing. I had to cut 3/4 of an inch out of the center to make it fit. The rear spoiler has about a 1/2 inch ADDED to make it fit flush end to end. Every piece of fiberglass had to have some type of major work but I am just about there. Dearborn or bust!
Quote from: pintosopher on November 19, 2013, 09:54:29 AM
Well,  I guess I don't get better lookin each Day! But I do get a bit more likable after a few Brews. ;D
LOL.. ;D ;D ;D
Quote from: Srt on November 18, 2013, 03:42:23 AM
from a really old post.....
".....I cloned the car into an extremely rare PERFORMANCE version of the 79 Cutlass called the W-30. No one bought it when it came out and no one remembers it now...."
I remember those cars! Funny, I don't FEEL that old (most days!)
I don't feel old myself until I look in the mirror...
It's been a while since I posted progress. I have been splitting my free time between the Lotus Pinto and my street Pinto. I have been massively reworking the glass doors, hood, and trunk taking out the waviness, dips, bumps, and adding glass to get the gaps closer to factory on the Lotus Pinto. It has been way more time consuming than I thought it would be. OCD can be fun  ;) . I'll post pictures once it's back in primer. I changed the front disc spindles to 73s to get to use the larger beefier tie rod ends. I then had a custom bump steer kit machined so I could still use the 71-72 Wilwood rack.
I have also added a section to the rear spoiler I got from MAP351. I wanted it line up with the edge of the glass trunk lid. I have not done glass work since my surfboard days but I think it turned out pretty good. :)
raynmaker
Any updates?  Quite an amazing car would love to see video of the race.
I was able to test fit the adapted starter by removing the transmission from the bell housing and rebolting the bell back on to the block. I put a hose clamp on the starter behind the gear so when I mounted it to the bell it would be fully extended to test the meshing of the starter gear to the flywheel. It's dead on. It is hard to see from this picture angle (taken through the bell opening) but there is about 1/16th of an inch of space before the gear bottoms out into the flywheel gear. Not bad for handing the Machinest an extra lotus flywheel, the starter and a sandwich plate from a 2.0L (no bell, no block). ;)
Quote from: skrach on September 05, 2012, 09:17:37 AM
I have the original tri-fold brochure for the hanto pinto. I will find it and scan it. I have a few I think. If I have more than one I will gladly send you one.
Douglas, PM Sent
skrach
thanks,
Douglas Johnson
"Skrach"
www.VividlyVintage.com
glad to see that you are still working strong on the project! keep up the good work!
WOW it's been a long time since my last update but I finally solved the major last roadblock to my progress. How to make a starter work on my Frankenstein of put togather parts. The problem was using a 3 hole mount bell housing (2.0L) from a 1971 pinto and mating it to a Ford Lotus block (1966) that normally used a 2 hole starter mount. 2 more issues, a smaller Lotus flywheel with different sized teeth. No one on earth makes an adapter (I know I looked for years). It kept me up nights. I finally found a machine shop that would take on the challange. They promised the job in 2.5 weeks but it took 3.5 months and below are the results. Pure art work at $260. Now I have NO excuse not to finish this project  ;D  71HANTO
Original 3 hole Pinto starter with the XLT race starter (1/3 of the weight) and adapter plates 2 hole and new 3 hole.
Comparing the Pinto original and the adapted race starter.
Closeup of the different toothed gears. They look close but no cigar.
Closeup of the Lotus plate and the new plate. Both fully indexable.
This side shows the installed bearing in the new plate taken from the Lotus plate.
I ran across this post in a British car forum from 2007...
"I didn't know *where* to put this one since it's a US car with a Brit engine (isn't it usually the opposite is done?)
Anyway, I took this at Lime Rock about 35 years ago. I found it while I was scanning some other old pictures.
The event was one of the early Car & Driver Showroom Stock Sedan events. I know C&D brought their "00" Pinto but I think Bruce Cargill won in an SSS Dodge Colt (I think).
This thing didn't race but was in the pits and attracted mucho attention.
It's not a Pangra but a sort of similar idea with a Jensen/Lotus 907 engine. Name on the side is "Hanto".
Anyone recall these?"
Thanks Starliner,
I have been doing some quiet progress and will have a primered roller for Carlisle. Here are some resent pics of the progress as of last Thursday (getting soda blasted). I will be trailering it complete or not. It will be a roller with motor, trans, plasic windows and fiberglass hood, doors and bumpers. The race tires are on the rims ready to go (Toyo R888's 205 50 15s). The glass trunk lid I got from Canada is trash and unusable (took four months to get and it's junk). So i'm using the original steel one (still pretty light). My son is driving his 71 from Texas and we are meeting up there.  The big push is AFTER this event to get it fully sorted for Trans-Am vintage racing...
Starliner
This is an amazing build.   I have been following it with interest since the beginning.
I hope you have time to get back to it.
1973 Pinto 1600 - Sold!
1979 Pinto 2300 - Sold!
It took me years to find a copy of the original Hanto Pinto article but here it is:
71HANTO...update. I've been out of the game due to some major life changes (all good) but this last weekend I received tentitive approval by the president of the west coast chapter of Vintage Auto Racing Assoc. (VARA) and the Chief Tech Inspecter to race the 71 Hanto Pinto as a homologated vintage race car. Subject only to my providing proof of the existance of the original 1975 Hanto Pinto (easy to do).  This means I won't be thrown in with the exibition class of misfits. I will be racing with 510s, Lotus Cortinas, 912s, etc. It also means I can race for points instead of being an "also ran". :fastcar:
Quote from: r4pinto on May 14, 2009, 12:55:38 AM
That ain't a bad idea.. Quite the visonarry you are  ;D
Thanks, I'm trying find every tiny advantage I can...gotta' go kick some serious A$$ on the track...:fastcar:
