Date: 09/01/2017 11:58 am
Date: 01/06/2017 11:42 pm
Date: 08/08/2018 12:26 pm
1971 2 lt Cam
Date: 10/10/2020 06:27 pm
KYB shocks
Date: 02/08/2017 07:09 pm
1977 Pinto for parts
Date: 10/10/2018 06:25 pm
Date: 09/19/2019 04:43 pm
2 liter blocks and heads
Date: 03/28/2018 09:58 am
Date: 07/17/2018 09:22 pm
  • Online today: 531
  • Guests: 195
  • Total: 195
2.3 pinto bell housing thinkness...neeed a measurment
Started by the shadow, January 21, 2008, 07:11:43 PM
Blacksheep22
I work 10's so give me a day or two to get it for you. I have a couple trans under my trailer.
71 Pinto Mini-Stock 1994 Track Champion
72 Pinto all original 63000
73 Pinto Wagon 2.0  4 Speed 8inch
the shadow
here's the trans I want to adapt to a '89 ford 2.3 ltr, it's a mid 70's B/W 3 speed thats been shortened to 17" over all with a top exiting shifter .  it looks like an old  40's top loader and I need it for my champ car project,  the trans is between my legs and a T5 is to modern looking and way too long (the shifter is in my crotch lol).
the shadow
 trying to adapt a B/W 3 speed (from a ford truck -mid 70's) to a 1989 2.3 ltr engine thathas a t5 on it now. My trans guy says the B/W trans he has won't bolt to a t5 bell. he also says that the trans input shaft is 1/2" shorter then a stock 2.3 ltr t5 inputshaft so I'd need a shallower bell and suggested a late 70's mustang II or pinto bell? I've been looking for a late 70's 2.3  4 spd bellhousing but at this point I'm not sure the late 70's 2.3's had the same bell to engine bolt pattern????
basically , in a nutshell, I need to know if I can even get a bell to put a B/W 3 or 4 trans to a late model 1989 2.3???? I want to get rid of the T5 but keep the newer engine.
paul
Blacksheep22
I can get it for you but the 2.3 was 74-80 and they were all 4-speeds. Just curious, Why do you need the measurement? U need it from the rear mating surface at the trans to the mating surface of the block?
the shadow
looking for the  depth measurment from a 3/4 speed  2.3 bellhousing from a 70's pinto/bobcat etc.
  that would be a measurment from the rear face (where the trans bolts up to the bell) to the front face (where the bell attatch's to the rear of the block)
any help would be great!
Paul
