Wanted early pinto
Date: 10/03/2019 02:42 pm
71-73 Rear valance panel
Date: 01/14/2021 06:54 pm
73 rear hatchback glass
Date: 07/06/2017 11:33 am
77 pinto
Date: 08/22/2017 06:31 pm
Date: 02/18/2017 04:41 pm
Date: 02/28/2018 09:37 am
Date: 06/30/2018 09:48 am
Date: 03/06/2019 06:40 pm
1972 pinto grill
Date: 02/27/2018 12:13 am
  • Online today: 1,292
  • Guests: 450
  • Total: 450
Pinto Idling High: Help!
Started by Trigger01, January 14, 2008, 07:30:14 PM
Your engine is probably using the Holly 5200 like most 78 4cyl's I've seen. If so, it probably needs some adjustments done, primarily to the choke.
I have three copies of the adjustment "manual" (two sided piece of paper) for the Holley 5200. I will try to scan one and post it here so you can get your choke adjusted.
A moody choke isn't fun, I know it myself. But once you get it working, it's well worth all the time and effort. :)
Possibly a broken rheostat coil in the choke housing???
Not to make 'light' of your situation, but I bet there are LOTS of Pinto owners out there that have NO PITY for you; they WISH their chokes worked, at all!!
Trigger01
Quote from: 77turbopinto on January 14, 2008, 07:46:10 PM
I think the Pintos have a vac. idle control. I am not sure what years they had them, but I think 78 or 79 to 80. Easy to tell.
Might just need a choke adjustment.
Have your tried to do a "kick down" (a very quick stomp on the gas pedal)?
Every time, occasionally it works, but doesn't most of the time.
-Mike
MCarrTrigger01@aol.com
SOLD
1978 Pinto Runabout
2.3 liter 4-cylinder
4-speed manual trans.
Daily Driver:
Heavily Modified Lifted '01 Ford Ranger Edge
Trigger01
Thanks, I will look into that. I am glad I don;t have to deal with a carb on my Ranger.
-Mike
SOLD
1978 Pinto Runabout
Daily Driver:
I noticed the repair books mention an idle speed control motor. If you have that on your Pinto & it's bad it will cause exactly what you're describing. Pretty common on later model Fords, & have seen it on a Ranger carb I bought once before.
Trigger01
I have a '78 2.3 4cyl that likes to idle high. It doesn't help that it's cold. I crank it up and let it run for a few minutes before I drive it and it still idles high. I don't even have to use the gas when I let out on the clutch. After a while of driving it it will go back down to normal idle, sometimes after 5 miles,sometimes after 15 miles. Any idea what's causing this?
Thanks in advanced for the help!
-Mike
-Mike
SOLD
1978 Pinto Runabout
Daily Driver:
