77 Cruising Wagon Front Seats
Date: 04/12/2017 12:37 pm
Misc pinto parts 71-73 2.0
Date: 05/05/2020 11:56 pm
Date: 09/10/2018 10:41 pm
Date: 08/17/2022 06:27 pm
Date: 11/11/2019 04:49 pm
Date: 02/28/2024 02:07 pm
1972 Pinto SCCA BS race car
Date: 10/23/2018 04:01 pm
Looking for a few parts - TIA
Date: 02/19/2023 12:18 pm
Built 2.0
Date: 10/07/2018 05:27 pm
  • Online today: 1,166
  • Guests: 140
  • Total: 140
Vacuum Connections for a 79 4cyl.
Started by TIGGER, January 12, 2008, 02:20:54 AM
bbobcat75
these pics are GREAT!! thanks for sharing!!!
1975 mercury bobcat 2.8 auto
junker
Boy I thought I had vacuum lines. Thanks for all the pics but I have a different kind of a beast. Boy I sure wish people would leave things the way they are suppose to be, the car runs so much better. I got the car running at cold start but when I drop it off fast idle it falls flat on its face, unless I keep my foot on the pedal,and until the soleniod on the carburetor kicks in it won't idle.
I believe he is talking about the sticker on the valve cover. Mine is also an Idaho Pinto. Same state all it's life. :)
Thanks and you are correct, the car is not a California Emissions car.  It was ordered in Idaho and was registered in Oregon after my dad took delivery.  I know what you mean about the added hassle as my Uncle that lived in California and had an 80 Bobcat Wagon for a number of years that he and I worked on from time to time when I came down to visit.  He had well over 200K on the original drivetrain when he sold it in 1999.  The guy that bought the car blew up the engine shortly after.
I am not sure what tag you are referring to but I only removed the timing cover to replace the timing belt.  Other than a good cleaning I did not do anything else to it.
cromcru
i noticed from your pics on the smog that your car is a federal smog car.those are easier to deal with then the california smog car.by chance did you keep your calibration tag on the timing chain cover.reading the smog diagrams can be miss leading at times. good pics. harold
Well even if it only has helped me, I hope it was worth it. I'm sure it will come in handy for someone else in the future though.
None of the diagrams in pinto books have a clear way of mapping out the vacuum system as it seems every book names valves differently. I'm curious as to how the white valve (Distributor Vent Valve as called by Haynes) effects engine performance.
Driving the car to and from work today I noticed the car doesn't require as much footwork on the clutch to get the car going and it doesn't chug at all when the car first starts moving.
I'm very thankful and extremely happy to have my engine setup correctly after three years of it being rebuilt. I told my dad about it (he helped rebuild the engine) and he was thrilled that someone was able to help. :)
Your welcome Dave, I am glad I could help.  I have been meaning post this info for a while now.  I just needed someone interested to get me started  ;D  Take care
If the pictures don't load for some reason or if they ever go down, here is a text version of it (assuming you know the valves spoken of):
Lower Thermactor Valve Port:
     * Intake vacuum nipple
     * Distributor vacuum advance
     * White valve on air cleaner - Outside port
            * Choke - Inside port (On white valve)
     * Underside of air cleaner - Left/Passenger side port
Upper Thermactor Valve Port:
     * Red valve on air cleaner - Lower port
Air Cleaner Flapper Valve:
     * Underside of air cleaner - Right/Driver's side port
Charcoal Box Under Fender:
     * Crank case vent valve (PCV Valve)
     * Vacuum block (rear of intake manifold) - Outside port
Vacuum Block Valve (rear of intake manifold)
     * Base of carburetor - Inside port
     * Charcoal under fender - Outside Port
I realize I have missed both green valves on the air cleaner, but I did not have them on my system and had to bypass them to match your pictures/diagram.
This is how I wrote down everything onto paper so I could go to the engine and change things. I did this on my 78' Sedan with manual steering and a 4 speed tranny. No AC or power brakes.
This has helped me tremendously! I can not thank you enough for posting this.
Now that I have my vacuum lines all sorted out and connected properly my trusty pinto drives better than ever. And with a new engine to pair with, like new!
I hope to see some good gas mileage improvements with this too.
Initially I was confused because there was a two way splitter connected to the red valve on the air cleaner and the carburetor base connection was somewhere else.
More Pics
More Pics
Here are a bunch of pictures from my 79 wagon.  The car is all original and pretty much unmolested under the hood.  It is a 2.3L 4spd car with dealer air that my Dad special ordered.  The carb in the pic is a NOS 80 carb so the connections for the choke are a little different.  I made an adapter pigtail so I can put the original carb back on that I had Pony Carbs rebuild.  I used this car as a guide when I did the motor and transmission swap on my 78 Crusing Wagon.  I copied all the connections and have had no problems with the Cruising Wagon since therefore I assume other years are similar.  I created the pictures in Power Point and I will convert the file to .pdf in case anyone wants an electronic copy.  Let me know if there are any questions.
