hood for a 79-80
Date: 11/30/2018 10:55 pm
Various Pinto stuff for sale.
Date: 11/21/2018 01:56 pm
Date: 10/24/2019 01:43 pm
1976 Squire wagon
Date: 09/12/2018 10:30 pm
Pinto 4-spd transmissions
Date: 06/15/2018 09:15 am
Hoard of Pinto parts
Date: 12/17/2016 04:14 pm
Date: 04/14/2023 06:15 am
Date: 08/08/2017 01:44 pm
Date: 11/08/2020 02:10 pm
  • Online today: 176
  • Guests: 192
  • Total: 192
frame connectors & traction bars
Started by 78pinto, June 18, 2004, 12:27:57 PM
they are aftermarket, i had to make the hole for the mounting dowel a bit bigger to fit on the spring perches
CHEAPRACER
Are these factory on a Ranger? 4 wheel drive? Did you have to modify them to make them fit? I need a pair.
they are 3 inch blocks, they are from a ford ranger.
Where did you get the 2" lowering blocks? All the ones I find for a pinto are 1" max. Thanks, DICK
copy away....all i know is that it works! I didn't build it, the fellow that owned it before me had someone do it. It was a race car and went 11.5 all day long with that set up with a 1.5 to 1.6 second 60 foot time :o
CHEAPRACER
ladder bars have no pivot point on the rear axle,  they are locked solid. His design still alows the rear to move up and down using a second pivot point but the axle will have to twist very slightly to allow this. on lauch, it's looks to me like the rear will try to pull itself away from the leafs but maybe the foward motion of the axle balances it all out. Maybe I'll copy it if you don't mind.
Quote from: Pintogary on June 29, 2004, 03:12:37 PM
Just an observation of your photos:  No wheel hop  because you have essentially locked the rear suspension with this setup.  Your 'traction bars' have a different pivot point than your leaf springs.  This is the same as a ladder bar setup.  You need floater housings on your axle for this to work properly.
This works great, i get full suspension travel and no wheel hop. With the car on the ground sitting normal, you adjust the bars so they move freely. If it aint broke....don't fix it! ;D
Pintogary
PINTOGARY
'74 Pinto 289V8 HotRod
straw boss
What size tubing are you using for the subframe connectors?
traction bar axle mount
traction bars front mounting
same.... the back
subframe connectors
i took some pictures while it was on the hoist getting some tailpipes put on. This setup works great, very little body flex and NO wheelhop at all!
