Pinto Runabout wanted
Date: 06/05/2018 04:42 pm
1971 Pinto
Date: 03/04/2017 11:28 pm
Date: 03/29/2019 07:20 am
1980 Pinto-Shay for sale
Date: 07/07/2016 01:21 pm
Date: 09/26/2019 05:31 pm
1971-74 Various Pinto Parts
Date: 01/18/2020 03:44 pm
Date: 10/02/2017 02:16 pm
Date: 09/01/2017 07:52 am
Date: 10/26/2020 03:24 pm
  • Online today: 802
Fiberglass front clip?
Started by Mutant pony, January 09, 2008, 09:08:20 PM
NoForKin
dam
            i need a grill 4 my 71
wedge446
This front end I got needs a grill.. will any grill from a 77 thru 80 fit?
NoForKin
           the hood on my 71 weights about 3 pounds you can pick it up with 1 finger and the trunk is made of ultra-light weight glass and weights1.1 pound. im not sure what the rest of the front end weights as it was on the car when i got it.
                   NoForKin
LBF
I had a one piece fiberglass front end on my '73 Pinto.  I had a L88 scoop molded onto it and it was pinned on in six places - near the windshield, at the front (the more-or-less "normal" location) and behind the front wheels.  It was difficult to remove unless you had two people lifting it.  When I sold that car the new owner supposedly cut out the "hood" portion to make it easier to check the oil...
I ordered it fron JC Whitney - I have no idea who made it.
NoForKin
hairy glass is what i thought
  i have his stuff on my 71 ,glass front end /hood/trunk lots of fitting work to get it to look right my 71 went 10.27@131.50 mph
Wedge446,
    I pictured it with the hood integrated into it...You wouldn.t need to tilt that cause you can flip the hood. I like it...I particularly like the bumper integration. If you fab the right stuff you could bolt that baby on.   Thumbs up.
wedge446
I think I`ll make it a pin on, tilt is just too much hassle..
I was told the maker of this front clip was   http://www.bruisglassworks.com/pinto.html
I called the maker and they said they didn`t offer pinto fiberglass, I pointed out to them that there web site says they did..
Long stort short,there customer service sux..
If they did make this clip I must say it is race weight fiberglass,very thin in spots.. It will take awhile before I can check  the fit... I want to add some more glass to the week spots..
I wouldn`t have paid full price for there glass, the quality just isn`t there but for what I paid for it.. I couldn`t good wrong.
(Thank Coy)
Here are a few pics of it.
http://s32.photobucket.com/albums/d30/wedge446/75%20Pinto%20wagon/
V8pinto_306_n2o
Are you going to make it pin-on or flip front?
pics pics!
Thats right I have seen that front clip plug in the lot behind the shop...
I'm related to Hairy West... his stuff is not junk.
alot better than A-1 and the rest.
FrankBoss
wedge446
Quote from: NoForKin on January 17, 2008, 08:41:26 AM
just wondering where you were able to find a fiberglass front clip??
                            NoForKin
Harry glass in Jacksonville,Fl. has one..He says its a direct bolt on.. He claimed to have made the mold from his 77 pinto.
NoForKin
                            NoForKin
wedge446
I`m picking up one this weekend.. I`ll get some pics and give a review when I get it home.
They are pretty cool if you set them up right. Body work is not really the issue. The real challenge is conforming and fastening it to the body. And if you want it to tilt forward on hinges...well that requires some inginuity. I put one on a 69 Javlin, it even raised and lowered by using the lift system out of a convertable. If you get that front end I would like to see pictures....or share with me where you purchased it.
A quality piece would need some trimming to get to fit properly. It shouldn't need any major surgery to go on the car.
V8pinto_306_n2o
I've been eyeing those too.  Always shied away from buying one because I figured some glasswork would be involved to make it work.  Not sure though.
Mutant pony
Do any of you guys have experiance with the one piece fiberglass front clip? I've been planning to buy one for years but, I'm pretty impatient with body work. I'm sure they are going to need some work to fit good.
'77 pinto,Reinforced stock chassis.2300,courier trans, np205 transfer,9" rear,427/430 gears
