convert to stick
Date: 05/19/2018 09:26 pm
Date: 08/30/2018 12:59 am
2 liter blocks and heads
Date: 03/28/2018 09:58 am
Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
Pinto Wheel Well Trim
Date: 03/29/2017 11:35 am
Date: 10/24/2018 07:35 am
Date: 12/13/2016 10:25 am
Date: 09/06/2020 01:57 am
76 drivers fender
Date: 07/20/2018 08:24 pm
  • Online today: 481
  • Guests: 96
  • Total: 96
dual sump oil pan on a beastie v8
Started by vonkysmeed, June 17, 2004, 01:50:11 AM
claudermilk
It's an 82 'stang. :)  I have a concern about ground clearance since we intend to lower the car.
vonkysmeed
Since I have 2, I will give it a try (need to save $ anyway)  Thanks for the help.  I will keep updating the website as we work on the project.
73 Pinto Runabout
351w from 74 galaxie
Heads from 69 Mercury Cougar
6 point cage
it may have to be clearanced a bit....with a hammer to clear the steering rack (just don't beat the living snott out of it! ;D) Its close on mine ....but it fits
vonkysmeed
I currently have 2 pans, 1 from an 83 tbird and one from an 83 mustang.  It is my understanding that the pan needs to have a sharp angle from the sump to the rest of the pan unlike the standard car pan that gently slopes to the sump.  This is because of the crossmember on the pinto.  This is based on research that I have done to date.  That is why I thought I needed to get  one from a mustang 2.
Thanks
73 Pinto Runabout
6 point cage
Poison Pinto
Quotethanks, I will look for the other pan.  Will a 351w pan work on a 302w?  I am looking for cheap alternates
The 302 has a "car" pan (also used on 2WD trucks) and a "4WD truck" pan. You will need the car pan (the sump is at the front of the engine) and, obviously, the accompanying syphon tube/filter. These should be fairly easy to find at any salvage yard or parts store and relatively inexpensive.
vonkysmeed
Quote from: 78pinto on June 17, 2004, 12:13:56 PM
no you will need a front sump pan, mine is an F150 351w pan, they are front sump
73 Pinto Runabout
6 point cage
no you will need a front sump pan, mine is an crown vic  351w pan, they are front sump
vonkysmeed
Anyone know if a dual sump oil pan will work on a v8 conversion?  The engine I have has one and currently cannot find a used pan from a MII.  Any thoughts.
Also, to see the trouble my brother in law and I are causing, look at the following site...
http://mysite.verizon.net/res0pv34/
thank you in advance for your help
73 Pinto Runabout
6 point cage
