Date: 03/25/2019 09:02 pm
Date: 06/05/2018 09:13 pm
1971-73 2.0 motor moiunts
Date: 05/17/2024 09:18 pm
Date: 08/01/2023 06:53 pm
1980 Pinto-Shay for sale
Date: 07/07/2016 01:21 pm
Date: 04/10/2017 07:30 pm
Date: 03/29/2019 07:20 am
hood for a 79-80
Date: 11/30/2018 10:55 pm
Date: 01/19/2020 09:06 am
  • Online today: 529
  • Guests: 433
  • Total: 433
map light won't work
Started by r4pinto, January 06, 2008, 03:45:26 PM
Problem fixed. I found the contacts on the switch for the maplight were both corroded & pushed down too much. I took the switch apart & fixed it.
I got a question regarding the map light/ dome light that was optional in the Pintos.
I bougt one off quickrick a long while back & finally was able to get a bracket for it. I ran the extra wire I needed for it, mounted it on the roof, and the dome light worked perfectly, but the map light would not work. I checked the bulb on a known good circuit & the bulb is fine, the wire I added has power like it should, and it grounds like it should. When I took the light off the combo unit I was able to get it working, but when it was mounted like it should it doesn't work. Could it be the switch for the map light itself and if so is there a way to fix these?
